Discuss
GE Washing machine leaks
 in
Dishwasher Repair
Hi guys, My GE washing machine leaks as soon as it fills before any agitation begins. I'm assuming I
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » GE Washing machine leaks
  #1 (permalink)
Old 10-15-2008, 11:42 AM
Wadester Wadester is offline
Junior Member
Wadester is on a distinguished road
Default GE Washing machine leaks
Model Number: WLE4000B1WW   Brand: GE   Age: 1 - 5 years
Hi guys,
My GE washing machine leaks as soon as it fills before any agitation begins. I'm assuming I will need to replace the tub seal and bearings (since it is a little loud when it spins). I will also need a spanner wrench to get the hub nut off. I have the part numbers for the bearings and seal but need a part number for the spanner wrench. Any words of wisdom would be greatly appreciated because the wife is getting a tad cranky.
Thanks,
Wadester
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-15-2008, 01:22 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
Tub seals have not been a problem with these units, I would pull the front off the washer and see where the leak is coming from. If its the trans. lower bearing thats noisy, then you should replace the transmission. The transmission is supported at the top by a BUSHING in the tub, Bushings don't get noisy!!! PS. find a tech in your area and borrow his spanner wrench. (Be really nice!!!!!) The wrench is PRICEY!!!!
  #3 (permalink)
Old 10-19-2008, 07:47 PM
Junior Member
Default still looks like a seal
I pulled the front off and watched while it filled. When it was about half full the drip started. The drip was very fast coming from right above the transmission where it goes into the tub. It is pretty evident from the underside of the tub that water has been leaking from right there and has been getting spun from that point all over the underside of the macine. Thanks for the tip I think that really helped to nail down the problem. How expensive is a spanner wrench? Should I put a caliper on the nut to be sure of the size?
Thanks,
Wadester
  #4 (permalink)
Old 12-21-2008, 07:33 PM
tyrepros tyrepros is offline
Junior Member
tyrepros is on a distinguished road
Default GE Washer Top load water leak from above tranny
I just dissembled this GE top loading washer and replace everything (transmission bearing (plastic washer) outer tub bearing (brass sleeve, siliconed it in), main rubber tub seal, washer (with square hole), and both inner and outer bearing for the metal hub to ride in. This was to repair a leak that began ONLY once aggitation begins. Fortunatley I installed a leak pan as well and it still leaks from above transmission at outer tub bearing sleeve. Of course I am looking for inspiration here, but just a few things I thought about during the repair.
* the hub in the outer tub does not appear to be sitting flush on the plastic transmission bearing. I did silicone-rtv the new hub in place in the outer tub.
* There is a gap above the new outer tub rubber seal, I also siliconed the ouside of this to the outer tub and greased the inner lip to the tranny shaft. Nothing "sits on this gasket to keep it in place so to speak.
*the tub only begins dripping once aggitation has begun.
*Everything frictional got some synthetic grease and I did not cheap out on the hub nut wrench. I have the right one and it is very tight (hammered wrench a few times to lock it down, but I think the leak is lower. or right where that nut sits.
* could it be leaking into the tranny shaft where the aggitation section seals to the solid shaft section? New tranny or more silicone where the shaft exits from the other shaft?
Thanks In advance.
Joe M.
  #5 (permalink)
Old 12-21-2008, 07:45 PM
cuba_pete cuba_pete is offline
Junior Member
cuba_pete is on a distinguished road
Default Spanner Wrench
You don't need the spanner wrench, in my opinion. A lot of posts suggest using a hammer and screwdriver or chisel. I used a short pipe (monkey) wrench, gripped in one of the slots on the nut, and tapped the handle of the wrench with a rubber mallet. This worked great and I did not need to purchase a special tool.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
door leaks when washing explorerdude Dishwasher Repair 0 02-02-2008 09:01 PM
Washing machine leaks from bottom shechter Washer Repair 0 10-15-2007 01:26 PM
Washing Machine leaks when filling tank cheryla Washer Repair 0 09-28-2007 12:10 AM
Washing Machine Gtaeza Dishwasher Repair 0 09-27-2007 08:19 AM
washing machine takes hours to finish washing a load kelly Monday Washer Repair 2 09-26-2007 02:42 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
