Discuss
maytag 3oo dishwasher stuck in lock mode
 in
Dishwasher Repair
Hi I have a Maytag 300 dishwasher that is stuck in "lock" mode. I Uunhooked the ribbon connector and cleaned
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » maytag 3oo dishwasher stuck in lock mode
  #1 (permalink)
Old 10-02-2010, 02:15 PM
Junior Member
tugzz is on a distinguished road
Default maytag 3oo dishwasher stuck in lock mode
Brand: Maytag   Age: 1 - 5 years
Hi
I have a Maytag 300 dishwasher that is stuck in "lock" mode. I Uunhooked the ribbon connector and cleaned it and reconnected. I then tried to enter "Field test mode" and the lock light blinks a few times and then stays on. Still won't start. Could it be a bad touch panel or board?
Model MDBTT60AWW
Serial 32582864
Ads By Google
  #2 (permalink)
Old 10-03-2010, 03:31 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Could be either the control board or the keypad.
A model number may help others help you.
__________________
  #3 (permalink)
Old 10-04-2010, 08:27 AM
Junior Member
Default added model and serial number
Thanks Denman
I updated the post to include them.
  #4 (permalink)
Old 10-05-2010, 03:15 AM
Senior Expert
APP Volunteer
Default
Wiring information replacement parts for MAYTAG MDBTT60AWW Frigidaire/refrigerator | AppliancePartsPros.com
I currently cannot find a tech sheet for your unit so cannot provide a method for checking the keypad.
Check behind the kick plate to see if the tech sheet is there. It should have the pinouts for the keypad. You then can check them with a meter and if they check out OK then the likely culprit is the control board.
Still a bit of a crap shoot but your odds are better.
If it is not there from the sounds of your symptoms the control board would be my first choice.
You may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Remove the ribbon cable from the keypad to the control board at the control board.
Clean the edge connector.
If it is the type where there is not a connector just the insulation is removed, it can be cleaned with a pencil eraser. Do not use an ink eraser as it is too abrasive.
Check the tracks in the ribbon cable for hairline cracks. A magnifying glass helps here.
Would not hurt to clean the connector on the board. Use electronics contact cleaner or isopropyl alcohol and a tooth brush. Be gentle and do not reconnect till all the solvent evaporates.
Reconnect everything and give it a try.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thermador Dishwasher stuck in "drain" mode gavinreed Dishwasher Repair 0 12-21-2009 06:07 PM
Maytag Dishwasher stuck before rinse cycle and more... jwd0416 Dishwasher Repair 2 01-03-2009 06:12 AM
Dishwasher in lock mode cant restart it Pattyyour Dishwasher Repair 4 12-05-2008 05:14 AM
Maytag dishwasher stuck in heating delay cdgifford Dishwasher Repair 0 03-31-2008 08:17 PM
Maytag dishwasher stuck on drain cycle ak47jazzfan Dishwasher Repair 3 10-15-2007 10:35 PM
