how do I remove control module from Bosch dishwasher
My machine won't complete a wash cycle. It goes down to "1" then stays there. It will complete a Rinse/Hold cycle normally. I have read through other posts and it looks like I need to at least inspect the control module and possibly repair or replace it. How do I access the module? Do I remove the panel on the back of the door or go through the front? Thanks
The model number you posted is incomplete. It suppose to be two more numbers after "/". Verify and repost it.
Gene. |
Quote:
Sorry, the entire model # is SHE44C05UC / 40 |
You can find some useful information as well as a pictures in one of our previous threads: http://forum.appliancepartspros.com/...ishwasher.html
- The control module Part number: AP4434739 Gene. |
Thanks, I will follow the instructions. Is it possible that I damaged the module by running the dishwasher with low temp water? As mentioned, my water was at 105F (not sure why)?
Quote:
Keep us posted. Gene. |
I finally got the nerve (and time) to get to the controller and sure enough, I found a 'smoked' trace on the circuit board. I see that people have had limited success re-soldering the connection. I tried but I am not confident in the results as it looked like the relay pin was gone. Have you (or anyone) had any success replacing the realy?? It is a $1 part (+$7 shipping) but worth a try I think at least. Unless persuaded otherwise
did you replace the relay.
Quote:
Yes I did replace the relay. I followed some advice on an alternate (better) relay and so far 3 months into it, it is working wonderfully. I ordered 2 replacement relays from Digi-Key and with shipping it came to $5.87 (and that was two relays in case I screwed one up!). It took me about 10mins once I had the board in hand. The only trick is you want to make sure the replacement is snug to the board as it is taller than the original and will not allow the housing to close without riding it.
Go to digikey.com and type in either T7CS5D-06 or digikey p/n PB336-ND and that should bring up a 6VDC-12A relay at $1.90. As I understand it, the design is bad. The original relay is slightly undersized at 10amps. The replacement is 12amps. Just have to throw in: Not impressed with Bosch (or whoever) not owning up to marginal design. GOOD LUCK! |
she44c05uc/22 Control Module removal and replacement
Quote:
Thanks. |
| All times are GMT -7. The time now is 10:08 PM. |
