Discuss
Remove panels to access barrel
 in
Dishwasher Repair
I need to replace my dryer belt, I'm having problems trying to get inside,how do I go about
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Remove panels to access barrel
  #1 (permalink)
Old 10-13-2008, 12:54 PM
charmart1 charmart1 is offline
Junior Member
charmart1 is on a distinguished road
Default Remove panels to access barrel
Brand: Whirlpool   Age: 1 - 5 years
I need to replace my dryer belt, I'm having problems trying to get inside,how do I go about removing which panel, step by step and replacing the belt? I have a 27" Whirlpool electric dryer. Thanks for any help
  #2 (permalink)
Old 10-13-2008, 01:18 PM
libertyappl libertyappl is offline
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Please post your model number.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 10-13-2008, 04:07 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
Remove the 2 screws under the lint filter, Put your Rt.Knee to the front of the dryer, with your left hand pull foward on the left side of the console down near the top of the dryer, and lift the left front of the top. Repeat for right side. Lift the top past 90degrees and lean it on a wall. disconnect wiring to the door switch, remove 2 screws from inside dryer going into the front panel,Lift slightly and remove from CLIPS at lower corners of thr front of the dryer, Install belt and put it all back together!!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Barrel seems to have dropped jmeeks Washer Repair 1 09-14-2009 07:33 AM
How to remove rear panel or otherwise access mechanical components mrvirta Dryer Repair 3 06-30-2009 07:54 PM
How do I remove the panels HappyPappy Washer Repair 1 09-12-2008 09:13 PM
How to remove panels to access coils Davidrod777 Dryer Repair 3 08-22-2008 10:25 AM
how to remove inner door panel to access glass radman Oven Repair (including Ranges and Cooktops) 0 01-26-2008 02:43 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
