Discuss
Mouse chewed sensor wire (LG)
 in
Dishwasher Repair
Hello. A mouse chewed the connector from the sensor on the front of the sump, visible behind the kickplate. Sensor
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Mouse chewed sensor wire (LG)
  #1 (permalink)
Old 09-29-2010, 10:04 AM
Junior Member
madcaroler is on a distinguished road
Default Mouse chewed sensor wire (LG)
Model Number: LDS4821BB   Brand: -other-   Age: Less than 1 year
Hello. A mouse chewed the connector from the sensor on the front of the sump, visible behind the kickplate. Sensor had 3 wires going to it; black grey, white. I need to know the order of the 3 wires to make a new connector.
For example... black, white gray (from left to rite)
Thanks!
Related Models
 LDS4821BB Dishwasher
 LDS4821ST Dishwasher
 LDS4821WW Dishwasher
 LDS5811BB Dishwasher
 LDS5811ST Dishwasher
 LDS5811WW Dishwasher
Amana LE1007W DRYER- ELE
General Electric LE1032H01 Counter top microwave
General Electric LE1032H02 Counter top microwave
Amana LE1100 DRYER- ELE
Amana LE1102 WASHER-TOP LOADING
Amana LE1102 DRYER- ELE
General Electric LE1460H01 Electric range
General Electric LE1460H02 Counter top microwave
Whirlpool LE2000XSW0 Residential Dryer
Amana LE2102L DRYER- ELE
Amana LE2102W DRYER- ELE
Amana LE2400 DRYER- ELE
Amana LE2402 WASHER-TOP LOADING
Amana LE2402 DRYER- ELE
Amana LE2500 DRYER- ELE
Amana LE2502 WASHER-TOP LOADING
Amana LE2502 DRYER- ELE
Amana LE2802 WASHER-TOP LOADING
Amana LE2802 DRYER- ELE
Amana LE2810 DRYER- ELE
Amana LE2811 DRYER- ELE
Amana LE2812 WASHER-TOP LOADING
Amana LE2902 WASHER-TOP LOADING
Amana LE2902 DRYER- ELE
Amana LE2910 DRYER- ELE
Whirlpool LE3000XMW0 Residential Dryer
Whirlpool LE3000XMW1 Residential Dryer
Whirlpool LE3000XMW2 Residential Dryer
Whirlpool LE3000XPW0 Residential Dryer
Whirlpool LE3000XSW0 Residential Dryer
Whirlpool LE3000XSWO ELECTRIC DRYER
Whirlpool LE3005XPW0 Residential Dryer
Whirlpool LE3300XPW0 Residential Dryer
Whirlpool LE3300XSW0 Residential Dryer
Amana LE3402G DRYER- ELE
Amana LE3402L DRYER- ELE
Amana LE3402W DRYER- ELE
Amana LE3502L DRYER- ELE
Amana LE3502W DRYER- ELE
Amana LE3802L DRYER- ELE
Amana LE3802W DRYER- ELE
Amana LE3902L DRYER- ELE
Amana LE3902W DRYER- ELE
Frigidaire LE400AXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE400AXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE400AXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE400AXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE400MXD1 Wwh(v2) / 27 " Laundry Center
Frigidaire LE400MXD2 Wwh(v2) / 27 " Laundry Center
Frigidaire LE400MXD3 Wwh(v1) / 27 " Laundry Center
Frigidaire LE400MXW1 Wwh(v1) / 27 " Laundry Center
Frigidaire LE400MXW2 Wwh(v1) / 27 " Laundry Center
Frigidaire LE400MXW3 Wwh(v2) / 27 " Laundry Center
Amana LE4207L DRYER- ELE
Amana LE4207L2 DRYER- ELE
Amana LE4207W DRYER- ELE
Amana LE4207W2 DRYER- ELE
Amana LE4217L2 DRYER- ELE
Amana LE4217W2 DRYER- ELE
Amana LE4307L DRYER- ELE
Amana LE4307W DRYER- ELE
Amana LE4317L2 DRYER- ELE
Amana LE4317W2 DRYER- ELE
Whirlpool LE4400XWW0 Residential Dryer
Amana LE4407L DRYER- ELE
Amana LE4407W DRYER- ELE
Amana LE4427L DRYER- ELE
Amana LE4427W DRYER- ELE
Whirlpool LE4440XWW0 Residential Dryer
Whirlpool LE4440XWW1 Residential Dryer
Amana LE4507L DRYER- ELE
Amana LE4507W DRYER- ELE
Amana LE4607L DRYER- ELE
Amana LE4607W DRYER- ELE
Amana LE4807L DRYER- ELE
Amana LE4807W DRYER- ELE
Whirlpool LE4900XKW0 Residential Dryer
Whirlpool LE4900XMW0 Residential Dryer
Whirlpool LE4900XMW1 Residential Dryer
Whirlpool LE4900XSW0 Residential Dryer
Whirlpool LE4900XTW0 Residential Dryer
Whirlpool LE4900XTW1 Residential Dryer
Whirlpool LE4900XTW2 Residential Dryer
Whirlpool LE4905XMW0 Residential Dryer
Whirlpool LE4905XMW1 Residential Dryer
Amana LE4907L DRYER- ELE
Amana LE4907W DRYER- ELE
Whirlpool LE4930XKW0 Residential Dryer
Whirlpool LE4930XMW0 Residential Dryer
Whirlpool LE4930XMW1 Residential Dryer
Whirlpool LE4930XSW0 Residential Dryer
Whirlpool LE4930XTW0 Residential Dryer
Whirlpool LE4930XTW1 Residential Dryer
Whirlpool LE4930XTW2 Residential Dryer
Whirlpool LE4935XMW0 Residential Dryer
Whirlpool LE4935XMW1 Residential Dryer
Whirlpool LE5200XTW0 Residential Dryer
Whirlpool LE5200XTW1 Residential Dryer
Whirlpool LE5320XTW0 Residential Dryer
Whirlpool LE5530XKW0 Residential Dryer
Whirlpool LE5530XKW1 Residential Dryer
Whirlpool LE5530XKW2 Residential Dryer
Whirlpool LE5530XMW0 Residential Dryer
Whirlpool LE5530XMW1 Residential Dryer
Whirlpool LE5530XMW2 Residential Dryer
Whirlpool LE5530XPW0 Residential Dryer
Whirlpool LE5530XSW0 Residential Dryer
Whirlpool LE5530XSW1 Residential Dryer
Whirlpool LE5535XPW0 Residential Dryer
Whirlpool LE5550XTG0 ELECTRIC DRYER
Whirlpool LE5550XTN0 ELECTRIC DRYER
Whirlpool LE5550XTW0 Residential Dryer
Whirlpool LE5600XKW0 Residential Dryer
Whirlpool LE5600XMW0 Residential Dryer
  #2 (permalink)
Old 09-30-2010, 04:26 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
I could not find info on your specific unit hopefully the following is a close match.
http://136.166.4.200/contents/Dishwa...ice_Manual.pdf
I am assuming you are referring to the soil sensor.
Pin 1 - White
Pin 2 - Black
Pin 3 - Grey
Often pin numbers are marked on the plug body or pin 1 will be marked.
Sorry I could not give you a definitive answer.
__________________
  #3 (permalink)
Old 10-01-2010, 08:31 PM
Junior Member
Default
Thanks very much. I'll give that a shot and see if it will work properly.
I could measure to determine ground pin.... it shouldn't destroy the sensor if i reverse VCC and Vout.
Will post with the results!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Wiring diagram for GE dryer needed: Squirrel chewed on wires wm1 Dryer Repair 0 08-29-2010 04:38 PM
Amana lever pully wheel getting chewed up Grimlock Washer Repair 0 06-27-2009 01:20 PM
Which wire to which terminal on the flame sensor? supertramp Dryer Repair 1 01-14-2009 12:58 AM
Dog chewed off wiring & tubing Moki Refrigerator & Freezer Repair 5 03-01-2008 07:11 PM
Moisture Sensor wire dwiley824 Dryer Repair 1 09-09-2007 09:21 PM
