| » water in water out |
That hum you hear is the motor attempting to start , this can be caused by a number of isses, the most common would be "something" stopping the motor and macerator from turning, not a tough task to get into the pump, remove the lower impeller and using a torx 15 bit unscrew the upper pump assembly, keep going until u see a screen and metal "blade" and make sure it can turn freely, a bad control board or the motor itself would cause same thing
| Display Modes | |
| water lines to hook up to the water valve on a kenmore coldspot | simonf22 | Refrigerator & Freezer Repair | 0 | 12-17-2009 12:16 PM |
| How Can I replace Water Pipe that is connected from Water Dispenser valve to Dispense | Rashmikant | Refrigerator & Freezer Repair | 0 | 11-23-2009 03:04 PM |
| Motor humming and water comes but blades don't spin (water pressure problem?) | mtheriault3 | Dishwasher Repair | 4 | 01-11-2009 04:18 PM |
| made clunking sound on ice and water dispenser now iced nor water works | crazyman | Refrigerator & Freezer Repair | 1 | 09-08-2008 01:12 PM |
| Whirlpool LA5300XM Cold water trickles, warm water flows properly | ajaysheetal | Washer Repair | 2 | 02-14-2008 04:49 PM |
