Door Had Leak At The Bottom .when Taken Apart Found A Plastic Strip That Seals The Door To The Bottom Lip Of Washer .mounts Inside Door Up To The Soap Disspencer Tray . Need To Know If It Should Be Glued In Place And Which Way To Mount It ?
