:eek: at first lights onthe cycles stopped working (smart wash 1st) continuing to the right till one day i went to unload and saw that it didn't finish the cycle. pushed start w/no result. i then unplugged dswshr paused then plugged in no result.checked door latch not the problem,thought it was control board (a repair man came looked at dshwshr agreed w/ me (wife was there not me )so i replaced cntrl brd. when i plugged it bck in heard motor running only shut off when i popped the door & it shut off. iwent out and reset the circuit brkr rptd what i did before (same result) now ipressed cycle buttons (smrt wsh:nthng,pots-n-pans:nthng,normal:lit up simultaneously w/heated dry(hmmm)same results 4 light wash fast wash the ht dry does'nt light up. my uneducated guesses are the start bttn, the heating coil ? what is the pattern to do diagnostic test ? hellllppp!!!
