Problem began by tripping 20 amp breaker twice after resetting and starting cycle over. Now machine runs through cycle, often continues on through end of cycle and will not drain. It has stopped tripping breaker. Machine starts, circulates and heats, but will not drain. Checked drain pump, impellar is clear. Removed wiring and applied 120v directly to pump motor and it runs fine. Checked the resistance at front panel on: >drain pump >circulation pump >measure det. actuator >Water inlet switch and valve All check out ok.
What is wrong? Tks.
