Hi.. new to the posts...
The dishwahser leaves the dishes wet. I checked the "normal" things. Hi-Temp temp "OK", Heater element "OK". Ran the self test--- on test 8 (dry) the heater turns on and I verified 120V and the element got hot. Only thing is the LED for DRY did not come on as stated in the test.
seems weird, I going to hook up a test light to the heather to see if during the dry cycle that there is 120 there.
Dose the TEST cycle verify the same elemets as a normal cycle? ANy ideas?
