Installed your part BSH 425458 water valve assy. Running the dishwasher. Seems like it has been for at least 2 1/2 hours or more. The water is hot & clear inside. It keeps "cycling", makes the sound that can hear through the sink... drain/whirr, pause, drain/whirr, pause, drain/whirr pause.... I believe 3 times in each cycle, then pauses longer.... then starts again. Shouldn't it be done? Shouldn't it just drain and stop? I now can hear my well water pressure tank going so it must have drained the tank. Thanks.
