| » Faulty spray arm blockage message |
Model Number: GSD2800P36 Brand: GE Age: More than 10 years
Several minutes into a wash cycle I always get an erroneous blocked spray arm message. Pressing the Start button will allow the cycle to continue OK even with the reed switch disconnected. I have correct voltage (13v) to the spray arm sensor reed switch. I've tried shorting out the reed switch to simulate always having a spray arm rotation pulse available to the control assembly but this didn't help. At this point it seems like the control assembly might be at fault but I'd like to make sure before replacing this expensive item. What additional tests can I do to isolate the problem?
Hello Dave Northrop,
The first thing I would do is remove the lower spray arm, take a part the spray arm hub & pinion and the bearing and make sure everything clean. This is one of the most common cause for the error code. Good luck. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Hello Dave,
In that case most likely the problem is a bad control board. How old is your dishwasher? Gene.
__________________
Hello Dave,
Besides the control board it also could be the spray arm sensor. Due to this part is no longer available and I can not assure you that replacing the control board would solve the problem, you probably have to think about a new dishwasher. Gene.
__________________
| Display Modes | |
| Install spray arm | rshaffer | Dishwasher Repair | 2 | 09-20-2007 04:00 PM |
| p/f message---cycle stops | snuffydog | Dishwasher Repair | 1 | 09-19-2007 10:30 PM |
| lower spray arm | jiml | Dishwasher Repair | 1 | 09-10-2007 09:38 AM |
| Spray arm | romeroom | Dishwasher Repair | 2 | 09-08-2007 01:42 PM |
| Oven oesn't bake/heat and displays a "FS" error message | jnymdnyt | Oven Repair (including Ranges and Cooktops) | 5 | 08-06-2007 07:36 PM |
