Discuss
Whirlpool dishwasher does not drain
 in
Dishwasher Repair
The dishwasher does not drain during wash cycles or with cancel/drain. Using your diagram I have taken apart the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool dishwasher does not drain
  #1 (permalink)
Old 09-25-2007, 01:49 PM
Sdj Sdj is offline
Junior Member
Sdj is on a distinguished road
Default Whirlpool dishwasher does not drain
Model Number: DU943PWKQ0   Brand: Whirlpool   Age: 1 - 5 years
The dishwasher does not drain during wash cycles or with cancel/drain. Using your diagram I have taken apart the pump assy and have found some small debris but no visible damage to any of the parts. I have checked the following:
Model #DU943PWKQ0
Motor runs and appears to spin drain impeller in the correct direction, counter clockwise looking down from the top of the impeller. Spinning the drain impeller by hand pushed water into the drain port.
No damage to the wash or drain impeller. All teeth remain, no cracks, and keyway is intact.
Drain hose not clogged, no air gap present.
No solenoid seems to be present, just a backflow check valve which is not clogged.
The only sign of damage is where the grinding impeller (item 19 in your diagram) meets the drain impeller. The spring end fits into a notch in the drain impeller to spin the grinding impeller. This notch is chipped, but the spring still fits in it and spins the grinder.
All gaskets appear to be fine, and the unit has never been apart before.
When opening the door to stop the drain cycle, there is a gurgling like there is some sort of backflow happening but I cannot figure out why. There are 3 check balls present, and all are in good condition. I wonder if they could have been knocked out of place to allow backflow and cavitation of the impeller? Other than that I have no ideas.
Any insight would be appreciated.
Thanks,
Scott
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-27-2007, 04:25 AM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Does the dishwasher spray up water well enough to soak dishes, if not you might have a clogged screen under the spray arm housing.
If ok I would remove the drain hose from the drain and put it in a bucket. Fill dishwasher, select drain, and check for proper volume flow. If ok, you might have a clogged drain, just check.
__________________
  #3 (permalink)
Old 10-01-2007, 10:43 AM
Tomas Perez Tomas Perez is offline
Junior Member
Tomas Perez is on a distinguished road
Default
Yes it does.
  #4 (permalink)
Old 10-02-2007, 03:43 AM
Senior Expert
APP Volunteer
Default
Unscrew the white plastic part that the drain hose clamps on and check the check valve there, might be bad/jammed.
__________________
  #5 (permalink)
Old 10-03-2007, 06:13 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi Tomas
In addition to the advices from richappy: you said there is no air gap which means the drain hose is connected straight to the garb disp. My question is: did you or someone else replaced the garb disp recently?
If your answer is Yes, then is the plug in the garb disp for the dishwasher drain connection has been removed?
If not that's why your dishwasher is not draining.
__________________
Professional appliance repair in Los Angeles, California.
  #6 (permalink)
Old 10-09-2007, 11:09 AM
lestouffer lestouffer is offline
Junior Member
lestouffer is on a distinguished road
Default
Quote:
Where is this diagram, I have been searching the site to no avail.
TIA
  #7 (permalink)
Old 10-09-2007, 11:32 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Hi lestouffer
We need the complete model number of your dishwasher.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
dishwasher won't drain walknite Dishwasher Repair 4 11-20-2008 04:08 PM
Replacing Drain Hose on Bosch Dishwasher Lorenzo Dishwasher Repair 3 10-02-2008 12:31 PM
Bosch Dishwasher Won't Drain jshoe01 Dishwasher Repair 2 09-06-2007 11:27 AM
Dishwasher - Whirlpool mhedges168 Dishwasher Repair 1 09-05-2007 12:21 AM
Whirlpool Dishwasher Jon Ziarko Dishwasher Repair 1 08-09-2007 05:54 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
