Discuss
Leaking Dishwasher
 in
Dishwasher Repair
I don't have the model number handy, but can look it up if necessary. This unit is the smaller
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Leaking Dishwasher
  #1 (permalink)
Old 10-04-2008, 09:15 PM
tropical36 tropical36 is offline
Junior Member
tropical36 is on a distinguished road
Default Leaking Dishwasher
Brand: Kenmore   Age: 1 - 5 years
I don't have the model number handy, but can look it up if necessary. This unit is the smaller 18" W size. It leaks at each bottom corner of the door and I believe it began when the wife used the wrong soap by mistake and created mounds of monster suds. It really leaked at first, but has subsided considerably since then, as the suds have finally went away with repeated washings and rinsing. We had this problem when it was still new and under warranty, which turned out to be the spray arm that spins around at the bottom. It had opened up a little, creating a sideway spray. The replacement part seems to be OK, as does the gasket, so now I'm wondering if the water level might be too high and how to adjust that. There is a clue, in that, I don't think it leaks until it starts the wash and rinse cycle, pointing back to that spray arm again, but as I said, it looks OK.
Any help and input on this will be appreciated.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
leaking dishwasher verne k Dishwasher Repair 6 09-15-2008 09:03 AM
Leaking dishwasher dcooker85 Dishwasher Repair 20 03-21-2008 07:15 PM
Leaking Dishwasher EMHBARMAN Dishwasher Repair 1 02-29-2008 05:58 PM
Dishwasher leaking while off jwcyre Dishwasher Repair 2 02-28-2008 01:44 PM
Dishwasher leaking jeremiah Dishwasher Repair 3 11-14-2007 12:02 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
