| » Dishwasher has developed a leak |
Model Number: GU1200XLTS2 Brand: Whirlpool Age: 1 - 5 years
I have traced the leak to the right front corner. It starts after it fills up.
The leak is coming from the float standpipe. I can reach underneath and get the water to shut off. So I think the switch is good. The float had a bunch of crude built up underneath that I cleaned up. I feel The level is about 1/8 inh to high. Is it adjustable? If I could drop the water leavel slightly it would not leak past the float. TIA John |
Any help Would be great. The level switch is still leaking. I think I have
Located the leak due to a Slightly high water level. I can look underneathe the unit while it is running and see the drip coming from the r.s. front of the unit. It's coming down the tube the mushroom shaped level float slide up and down in. Any Help? |
Hi John,
The only way to adjust the water level is to decrease amount of water by turning down the water shut off valve under the sink. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Drags
Thanks for the response. I think if I understand Gene's post I should use the shut off valve under the sink to confirm my diagnosis and yours to make it a fix. Did I interpet those answers correctly. It looks like 1/16' is about all you could safely remove from that litttle "Nub" on the bottom of the float. |
| Display Modes | |
| GE dishwasher leak from front | donnamintzer | Dishwasher Repair | 0 | 06-10-2008 03:05 PM |
| dishwasher leak | ken rapoza | Dishwasher Repair | 0 | 11-19-2007 05:53 PM |
| dishwasher leak | ken rapoza | Dishwasher Repair | 0 | 11-19-2007 05:41 PM |
| Dishwasher Leak | Ron P | Dishwasher Repair | 0 | 08-08-2007 12:58 PM |
| Dishwasher leak | chughes | Dishwasher Repair | 1 | 07-23-2007 04:53 PM |
