Discuss
Dishwasher has developed a leak
 in
Dishwasher Repair
I have traced the leak to the right front corner. It starts after it fills up. The leak is coming
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Dishwasher has developed a leak
  #1 (permalink)
Old 10-04-2008, 12:06 PM
Johnsue28 Johnsue28 is offline
Junior Member
Johnsue28 is on a distinguished road
Default Dishwasher has developed a leak
Model Number: GU1200XLTS2   Brand: Whirlpool   Age: 1 - 5 years
The leak is coming from the float standpipe. I can reach underneath and
get the water to shut off. So I think the switch is good. The float had a bunch of crude built up underneath that I cleaned up. I feel The level is about 1/8 inh to high. Is it adjustable? If I could drop the water leavel slightly it would not leak past the float. TIA
John
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-12-2008, 07:22 PM
Junior Member
Default
Any help Would be great. The level switch is still leaking. I think I have
Located the leak due to a Slightly high water level. I can look underneathe the unit while it is running and see the drip coming from the r.s. front
of the unit. It's coming down the tube the mushroom shaped level float
slide up and down in. Any Help?
  #3 (permalink)
Old 10-13-2008, 03:03 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi John,
The only way to adjust the water level is to decrease amount of water by turning down the water shut off valve under the sink.
__________________
Professional appliance repair in Los Angeles, California.
  #4 (permalink)
Old 10-13-2008, 05:20 PM
Drags1998 Drags1998 is offline
Senior Expert
APP Volunteer
Drags1998 is on a distinguished road
Default
The other thing that I have done a few times is shorten the FLOAT 1/16" You may have to do it a couple of times, Just do a LITTLE at a time!!!
  #5 (permalink)
Old 10-13-2008, 08:43 PM
Junior Member
Default
Drags
Thanks for the response. I think if I understand Gene's post I should use the shut off valve under the sink to confirm my diagnosis and yours to make it a fix.
Did I interpet those answers correctly. It looks like 1/16' is about all you could safely remove from that litttle "Nub" on the bottom of the float.
  #6 (permalink)
Old 10-14-2008, 03:35 PM
Senior Expert
APP Volunteer
Default
Yes, and also make sure that the unit is level to slightly tilted to the rear.Good Luck!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE dishwasher leak from front donnamintzer Dishwasher Repair 0 06-10-2008 03:05 PM
dishwasher leak ken rapoza Dishwasher Repair 0 11-19-2007 05:53 PM
dishwasher leak ken rapoza Dishwasher Repair 0 11-19-2007 05:41 PM
Dishwasher Leak Ron P Dishwasher Repair 0 08-08-2007 12:58 PM
Dishwasher leak chughes Dishwasher Repair 1 07-23-2007 04:53 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
