After finishing the cycle, the water came up agin in the tub,I already checked the hose (attached to the garbagge disposal), is working fine, I do not what else to do.
Thanks. I tried that there is no problem with the piston, the water is still in the tub, the pipe connected to the garbagge disposal is ok because the water flows good! How can I check if the water valve is working, because the tube is full again and thet water came trough that line and the water is hot.
Sorry for the delay. I'm afraid I did not get clear what is wrong with your dishwasher. It does not drain properly or it keeps filling with water when the dishwasher is off? If it keeps filling with water while the dishwasher is off and the door is open, replace the water inlet valve. No doubts about it. - The water inlet valve Part number: AP2039343
Thanks,I will change that part.
Thanks Gene my Dishwasher is working like a new one!!!.I could replace the inlet vale and it is working !!
You are welcome. I'm glad you were able to fix it.
Thank you for the feed back.
