Discuss
Whirlpool Quiet Partner 2 dishwasher
 in
Dishwasher Repair
Hi again all (especially Joe!)... OK, got everything taken apart, ordered the wrong thermal fuse, ordered the right one, and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool Quiet Partner 2 dishwasher
  #21 (permalink)
Old 09-25-2013, 04:33 PM
erf erf is offline
Junior Member
erf is on a distinguished road
Default
OK, got everything taken apart, ordered the wrong thermal fuse, ordered the right one, and now have the most ridiculous problem.
I snipped the wired from the old thermal fuse, stripped the insulation and now have to connect them to the terminal block on the new thermal fuse.
Problem: The wires will not stay connected to the terminal block.
I loosened the screws on the block, put the exposed wire ends into the holes, and tightened the screws until I couldn't tighten them any more. Result? The wires pop right out with just a mild tug (or less).
It's a very simple operation, which I've done before on other devices, but it's like the screws won't tighten enough to grab onto the wires and hold them. I tried stripping the wire with shorter or longer exposed ends, but no difference.
Have you ever heard of anything like this? Any suggestions? The wires from the thermal fuse to the terminal block seem to be very secure. Not sure what I could be doing wrong. The only thing is that the screwdriver I'm using to get to the screws that are that small has a VERY small handle... I'm wondering if that's preventing me from tightening the screw enough? I kind of doubt it, because when the wire pops out, it looks like screw is down pretty far, but maybe not far enough.
Any thoughts? I'm going a little nuts at something so simple causing so much trouble!
Thanks again (again!)
-Eric
  #22 (permalink)
Old 09-26-2013, 06:51 AM
Joe / APP Team's Avatar
Senior Expert
Joe / APP Team is on a distinguished road
Default
-Eric
Eric, Haven't had that issue myself, but then I had several "custom" tools for "special" occasions. A couple of things to try, Get an inexpensive set of "jewelers" screwdrivers from the local hardware store. If you have a soldering iron and solder, you could solder the end of the wire, so that when the screw tightens the individual wire strands don't separate and you'll get a very tight proper connection.
__________________
Thanks for allowing AppliancePartsPros.com to assist you,
Joe M. APP TEAM
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
  #23 (permalink)
Old 09-26-2013, 09:38 AM
erf erf is offline
Junior Member
Default
Hi Joe...
The soldering sounds like a good idea, still not sure if the screw will grab on to it though.
I was wondering about the screwdriver type you mentioned. I have some tiny screwdrivers, don't know if they're "jewelers" or not. The one I'm using is in the jpg attachment.
Is that the sort you're talking about? In any case, one with a wider handle would be, um, handy
Thanks again!
  #24 (permalink)
Old 09-26-2013, 11:42 AM
Senior Expert
Default
Hi Joe...
Thanks again!
Erf, Yes, that's a basic "jewelers" flat blade screwdriver, and it usually works pretty well. Your next option is the local hardware or auto parts store and purchase a 1/16 inch flat blade screwdriver, and try the solder.
__________________
Joe M. APP TEAM
  #25 (permalink)
Old 09-27-2013, 02:16 PM
erf erf is offline
Junior Member
Default
Eureka! It's fixed!
I got a flat blade screwdriver with an actual handle, and that did the trick. It's amazing what a little extra torque (and grip) can do!
Buttoned it all up and it's working! Hope this fuse holds up better than the original.
Thanks again SO much, Joe!
-Eric
  #26 (permalink)
Old 09-27-2013, 02:29 PM
Senior Expert
Default
Eureka! It's fixed!
-Eric
Erf, Check one more thing ... Remove the kick plate and power to the dishwasher, open the electrical junction box on the front or the dishwasher frame, and check , make sure the electrical connections, make sure the wires are wrapped tight together and the wire nuts are good and tight.
You're Very Welcome !!!
__________________
Joe M. APP TEAM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Gold Quiet partner III Dishwasher Chris6767 Dishwasher Repair 1 07-23-2010 05:30 PM
dishwasher whirlpool quiet partner 111 gold gu1100xtlq1 onerockman Dishwasher Repair 5 01-05-2010 06:06 PM
Whirlpool Quiet Partner IV dishwasher jmwolfe Dishwasher Repair 1 01-05-2010 05:28 AM
Whirlpool Dishwasher Quiet Partner III won't run!! babychix2004 Dishwasher Repair 1 12-01-2009 09:22 PM
Whirlpool Quiet Partner IV Dishwasher noise 123POW Dishwasher Repair 1 10-16-2009 06:53 PM
