| » how do i put this Clutch |
Model Number: 11082670810 Brand: Kenmore Age: More than 10 years
Please tell me how to put in this clutch?.
The first thing that you will need to do is remove the two Phillips screws that are located at the back of the control console, (Part #49 on the parts breakdown of the control panel.)
After you have done this, pull the control panel forward and upward. Next you will want to use a standard screwdriver, and pry the clips out at the back sides of the unit that connect the back to the case, this is done by inserting the screwdriver into the front slot, and push the screwdriver back, the clips will pop up. Unclip the wires that connect to the case in the center, then grasp the case and pull the top of it forward, the case should slide off exposing the whole interior workings of the machine. Now pull the top cap of the agitator off, there will be another cap under this, reach into the agitator and pull that cap up. Under this you should see a 7/16” bolt, you will need an extension to reach this and remove it. Grasp the bottom of the agitator and pull upward and remove the whole agitator. At the bottom in the center you will see the pump, it is held into place by two clips, remove them, and then pull the pump off, you do not need to disconnect the hoses from the pump. Behind this you will see the motor, it is also held in place by clips also sometimes these clips will have screws through them, it will not be necessary to reinstall these screws, they are for shipping purposes only. You will probably need to use a standard screwdriver to remove these. You will also need to remove the wires to the motor, if there is a capacitor on the side of the motor, remove the leads to it also, (it will not matter which lead you hook to on the capacitor when you re-install it. Now you will have the gear case exposed, it is easier if you tip the machine back, you will find three ½” bolts, remove these and the gear case will slide down out of the machine. DO NOT LEFT THE GEARCASE BY THE SHAFT AS THIS WILL CAUSE DAMAGE TO THE GEARCASE. Once you have completely removed the gear case and have it setting on the floor in front of you, you will see a bowl shaped object on the top, this is the clutch inside the bowl is a ring, you can use a pair of pliers to remove this. You might try to turn this ring inside the bowl before you remove if you can easily slide it then this is defiantly what you will need to replace. There is a washer that you will have to pull off of the shaft, below this you will see a clip that will have to be removed, and then another ring, I have found it easier to remove this with a screwdriver, once it is off, then pull the bowl upward Reverse this procedure, reading the directions that come with the clutch You will also need to replace the plastic which is the brake driver cam. It is held in place by a c/e clip, once you have done this turn and push upward on the brake so that it will be high enough when you go to reinstall the gear case. Just reverse the procedures to reassemble the unit. Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
no problem, it happens a lot ;o)
Nat
__________________
| Display Modes | |
| Clutch or no Clutch on the timer? | TimN | Dryer Repair | 2 | 02-19-2010 09:28 AM |
| Is it the clutch? | yochristy | Washer Repair | 2 | 06-03-2009 01:24 AM |
| clutch replacement | lenny prezorski | Washer Repair | 2 | 11-17-2008 07:59 AM |
| Ge Clutch Repair | JTW | Washer Repair | 0 | 11-03-2008 06:26 PM |
| clutch removal | thelazydentist | Washer Repair | 1 | 12-04-2007 12:15 AM |
