| » Bosch Dish Washer Latch problem |
Brand: Bosch Age: 1 - 5 years
In tne process of repairing and putting my machine back together I must of messed up the latch. Now the machine works but the lights don't and the machine works with the door open or closed. Is it just a loose wire or do I have to replace the latch?
Carol,
What is the complete model number of the dishwasher? You can find it on the right side of the door. Gene.
__________________
Professional appliance repair in Los Angeles, California. |
Bosch Shu9915uc/u12 FD8009
I saw the post from another user same model. I took latch out but I couldn't release or switch the latcht to open position or any other position. Last edited by carol kittelson : 10-01-2008 at 12:46 PM. Reason: more #s |
Carol,
Hopefully attached instructions will help you to fix the problem. Gene.
__________________
Gene,
Any advice? The detergent door does not close. Something seems to be stripped. The detergent goes into the washer immediately, so I assume the detergent gets washed down the drain too early. I found three possible parts to buy. Rinse aid door (with gasket) --$10 Part Number: AP2802335 Detergent door (with gasket) -- $22 Part Number: AP2802328 Dispenser assembly (vented) -- $56 Part Number: AP2802340 The dishwasher model is SHU9915UC/11 It would be great if you can help. It seems that you have good experience with Bosch dishwashers. Thank you, -Brian |
| Display Modes | |
| Bosch SHU9915 Door Latch Locked | lute | Dishwasher Repair | 1 | 06-08-2008 03:25 PM |
| Dish washer will not drain | Timbosch | Dishwasher Repair | 1 | 06-08-2008 10:35 AM |
| Dish Washer | George Madden | Dishwasher Repair | 1 | 01-13-2008 11:04 AM |
| dish washer | lsj1402 | Dishwasher Repair | 5 | 09-11-2007 05:00 AM |
| Dish washer not working | sylvia | Dishwasher Repair | 1 | 07-19-2007 12:24 PM |
