Discuss
Bosch Dish Washer Latch problem
 in
Dishwasher Repair
In tne process of repairing and putting my machine back together I must of messed up the latch. Now the
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Bosch Dish Washer Latch problem
  #1 (permalink)
Old 09-30-2008, 09:09 AM
carol kittelson carol kittelson is offline
Junior Member
carol kittelson is on a distinguished road
Exclamation Bosch Dish Washer Latch problem
Brand: Bosch   Age: 1 - 5 years
In tne process of repairing and putting my machine back together I must of messed up the latch. Now the machine works but the lights don't and the machine works with the door open or closed. Is it just a loose wire or do I have to replace the latch?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-30-2008, 06:09 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Carol,
What is the complete model number of the dishwasher? You can find it on the right side of the door.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 10-01-2008, 12:32 PM
Junior Member
Default model #
Bosch Shu9915uc/u12 FD8009
I saw the post from another user same model. I took latch out but I couldn't release or switch the latcht to open position or any other position.
  #4 (permalink)
Old 10-03-2008, 01:20 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Carol,
Hopefully attached instructions will help you to fix the problem.
__________________
  #5 (permalink)
Old 11-15-2008, 07:36 AM
BrianW BrianW is offline
Junior Member
BrianW is on a distinguished road
Default Bosch detergent dispenser does not close at all
Gene,
Any advice? The detergent door does not close. Something seems to be stripped. The detergent goes into the washer immediately, so I assume the detergent gets washed down the drain too early. I found three possible parts to buy.
Rinse aid door (with gasket) --$10
Part Number: AP2802335
Detergent door (with gasket) -- $22
Part Number: AP2802328
Dispenser assembly (vented) -- $56
Part Number: AP2802340
The dishwasher model is SHU9915UC/11
It would be great if you can help. It seems that you have good experience with Bosch dishwashers.
Thank you,
-Brian
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch SHU9915 Door Latch Locked lute Dishwasher Repair 1 06-08-2008 03:25 PM
Dish washer will not drain Timbosch Dishwasher Repair 1 06-08-2008 10:35 AM
Dish Washer George Madden Dishwasher Repair 1 01-13-2008 11:04 AM
dish washer lsj1402 Dishwasher Repair 5 09-11-2007 05:00 AM
Dish washer not working sylvia Dishwasher Repair 1 07-19-2007 12:24 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
