Discuss
Kirkland Costco Washer stopped during water filling
 in
Dishwasher Repair
When the washer is filling water, the washer stopped. I tried to start it again. The water only went on
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Kirkland Costco Washer stopped during water filling
  #1 (permalink)
Old 09-28-2008, 09:32 PM
Junior Member
cdng33 is on a distinguished road
Default Kirkland Costco Washer stopped during water filling
Model Number: SAWS800MQ   Brand: Whirlpool   Age: 1 - 5 years
When the washer is filling water, the washer stopped. I tried to start it again. The water only went on couple of seconds and then stopped. Tried 3rd time by pulling the switch back to start, nothing happens. Now no matter what I do, nothing happens. I set the switch to any duration of the cycle, wash/drain/..., nothing happens. I checked the latch(pin) for the cover. It came off easily. But I don't think it is bacause of the cover latch since the water should still fill when the cover is open. I may have just accidentally bump it off. Any ideas what could be wrong?
Ads By Google
Related Models
Whirlpool SAWS800MQ0 Automatic Washer
Whirlpool SAWS900HQ0
Whirlpool SAWS900JQ0
Whirlpool SAWS900MQ0 Automatic Washer
Whirlpool SAWX650JQ0
Whirlpool SAWX650MQ0 Automatic Washer
Whirlpool SAWX650MQ2 Automatic Washer
Whirlpool SB1000SKN0
Whirlpool SB100PEDB0
Whirlpool SB100PEDB1
Whirlpool SB100PEDB2
Whirlpool SB100PEDB4
Whirlpool SB100PEDB5
Whirlpool SB100PEK0
Whirlpool SB100PEK1
Whirlpool SB100PER0
Whirlpool SB100PES0
Whirlpool SB100PES1
Whirlpool SB100PES2
Whirlpool SB100PES3
Whirlpool SB100PES4
Whirlpool SB100PSK0
Whirlpool SB100PSK1
Whirlpool SB100PSR0
Whirlpool SB100PSR1
Whirlpool SB130PEDB0
Whirlpool SB130PEDB1
Whirlpool SB130PEDB2
Whirlpool SB130PEK0
Whirlpool SB130PER1
Whirlpool SB130PER2
Whirlpool SB130PER3
Whirlpool SB130PER4
Whirlpool SB130PER5
Whirlpool SB130PERW0
Whirlpool SB130PSK0
Whirlpool SB160PEDB0
Whirlpool SB160PEDB1
Whirlpool SB160PEDB2
Whirlpool SB160PEDB4
Whirlpool SB160PEDQ0
Whirlpool SB160PEDQ1
Whirlpool SB160PEDQ2
Whirlpool SB160PEDQ4
Whirlpool SB160PEEB1
Whirlpool SB160PEEB2
Whirlpool SB160PEEB5 24" Built - in - Oven Gas
Whirlpool SB160PEEB6
Whirlpool SB160PEEB7
Whirlpool SB160PEEB8
Whirlpool SB160PEEB9
Whirlpool SB160PEEQ1
Whirlpool SB160PEEQ2
Whirlpool SB160PEEQ5 24" Built - in - Oven Gas
Whirlpool SB160PEEQ6
Whirlpool SB160PEEQ7
Whirlpool SB160PEEQ8
Whirlpool SB160PEEQ9
Whirlpool SB160PEXB0
Whirlpool SB160PEXB1
Whirlpool SB160PEXQ0
Whirlpool SB160PEXQ1
Amana SB21VE Ref - SXS/I&W
Amana SB21VPSE Ref - SXS/I&W
Amana SB21VW Ref - SXS/I&W
Thermador SB2B
Amana SB520K Ref - SXS/I&W
Amana SB520SW Ref - SXS/I&W
Amana SB520TW Ref - SXS/I&W
Amana SBC24FX0 Range - Electric Std Delaware
Amana SBC24FX5 Range - Electric Std Delaware
Amana SBC24FXOW Range - Electric Std Delaware
Amana SBC26CK Range - Electric Std Delaware
Amana SBD20H Ref - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K Ref - SXS/I&W
Amana SBD20M Ref - SXS/I&W
Amana SBD20MW Ref - SXS/I&W
Amana SBD20NE Ref - SXS/I&W
Amana SBD20NW Ref - SXS/I&W
Amana SBD20Q2E Ref - SXS/I&W
Amana SBD20Q2W Ref - SXS/I&W
Amana SBD20S4E Ref - SXS/I&W
Amana SBD20S4L Ref - SXS/I&W
Amana SBD20S4W Ref - SXS/I&W
Amana SBD20TPE Ref - SXS/I&W
Amana SBD20TPL Ref - SXS/I&W
Amana SBD20TPSW Ref - SXS/I&W
Amana SBD20TPW Ref - SXS/I&W
Amana SBD21VE Ref - SXS/I&W
Amana SBD21VL Ref - SXS/I&W
Amana SBD21VPE Ref - SXS/I&W
Amana SBD21VPSE Ref - SXS/I&W
Amana SBD21VW Ref - SXS/I&W
Amana SBD522VE Ref - SXS/I&W
Amana SBDE20S4SW Ref - SXS/I&W
Amana SBDE20TPE Ref - SXS/I&W
Amana SBDE20TPW Ref - SXS/I&W
Amana SBDE21VPE Ref - SXS/I&W
Amana SBDE21VPSE Ref - SXS/I&W
Amana SBDE520K Ref - SXS/I&W
  #2 (permalink)
Old 09-29-2008, 06:45 AM
Senior Expert
APP Volunteer
libertyappl is on a distinguished road
Default
Check your water valve.
Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com
We are also Ministers that do a weekly jail house ministry.
Rate Liberty Appliance Service on MyPros.com
  #3 (permalink)
Old 09-29-2008, 09:59 AM
Junior Member
Default
The water valve is on all the time. I flipped it back and forth couple of times. If the water inlet line is clogged, it is supposed to spin when I switched it to the spin cycle. Correct? There is quite some water in the washer.
  #4 (permalink)
Old 09-29-2008, 10:21 AM
Senior Expert
APP Volunteer
Default
If the lid switch is broken or off it will not spin. But if the water valve located on the inside rear of the machine has malfunctioned you may not get any water in the unit. If the connections are loose or came off the valve that may be your problem.
Does the timer advance?
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer won't stop filling with water oerck157 Washer Repair 2 06-04-2009 11:01 AM
washer filling up with water reggierousseau Washer Repair 2 05-07-2009 11:13 AM
Washer stopped after filling, nothing SamRhinoREd Washer Repair 2 09-23-2008 12:31 PM
kirkland whirlpool washer fills with water but doesnt do anything after filling nikkismp Washer Repair 2 06-28-2008 11:39 AM
Washer stops after filling with water golfnut77 Washer Repair 1 02-26-2008 02:38 PM
