Discuss
soap dispensor problem
 in
Dishwasher Repair
The soap dispensor door will not open during the wash cycle. Is this repairable?
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » soap dispensor problem
  #1 (permalink)
Old 09-23-2007, 06:26 PM
dsoakes dsoakes is offline
Junior Member
dsoakes is on a distinguished road
Default soap dispensor problem
Model Number: 665.16761690   Brand: Kenmore   Age: 5 - 10 years
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 10-03-2007, 09:38 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Hi dsoakes
The first thing I would check are tabs holding the control panel to the door frame. Remove the screws around the inner door panel and remove the panel. Check the tabs on both sides of the control panel. If the right hand side tab is broken that what causing the problem. To fix it the console has to be replaced.
- The part number for the console AP3096891
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Replacing Soap Dispenser JWMc Dishwasher Repair 1 09-19-2007 06:49 PM
Soap Dispenser romeroom Dishwasher Repair 2 09-02-2007 02:18 PM
kichenaid superba soap dispenser ralph Dishwasher Repair 1 08-31-2007 04:47 PM
soap doesn't dissolve jmr Dishwasher Repair 0 08-12-2007 09:13 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
