tommy2tone
#1 Posted : Friday, September 10, 2010 7:41:23 PM(UTC)
tommy2tone
The dishwasher leaks when water is being pumped out of the washer - after the first rinse, then after the wash, then after the final rinse. The rest of the time, while washing, no leaks. total leak amount is about 1 cup per load. What shoudl I replace?
#2 Posted : Friday, September 10, 2010 11:13:02 PM(UTC)
Replacement parts for General Electric GSD1130R45WA Dishwasher | AppliancePartsPros.com
[COLOR="Blue"]What shoudl I replace?[/COLOR]
Only you can tell as there are a number of items in the drain path.
Remove the kick plate and find the leak.
May be as simple as replacing a clamp.
A small mirror and a flashlight come in handy when trying to track down leaks.
A mirror like the ones mechanics use, which is on a handle is ideal.
Yo could also tape a small mirror to a piece of doweling etc.
GSD5120D00BB GE dishwasher leaking at the bottom corners (Dishwasher Repair)
by ron Minervino 12/7/2023 9:15:11 AM(UTC)
GE Dishwasher leak from inlet port, left side, during wash cycle (Dishwasher Repair)
by pdpantages 3/15/2015 9:10:33 AM(UTC)
ge dishwasher leaking at bottom (Dishwasher Repair)
by Jerry7235 10/31/2013 1:48:10 PM(UTC)
GE Dishwasher leaking at shaft near solenoid valve (Dishwasher Repair)
by e-man 8/14/2011 6:55:10 PM(UTC)
GE Dishwasher Leaking Out Through Water InFeed during aggitation (Dishwasher Repair)
by andrewmcc 3/26/2011 3:20:29 PM(UTC)
GE Dishwasher leak (Dishwasher Repair)
by haneysuejohn 3/13/2011 3:14:57 PM(UTC)
GE dishwasher leaking at bottom right front door (Dishwasher Repair)
by ZincWhiskers 3/23/2010 12:03:20 PM(UTC)
GE Dishwasher Leaking (Dishwasher Repair)
by katiedbell 11/29/2009 4:50:08 PM(UTC)
GE Dishwasher leaking (Dishwasher Repair)
by must9450 9/11/2009 1:27:16 PM(UTC)
by _Joe_ 8/6/2009 8:52:48 AM(UTC)
GE Dishwasher Leak Problem (Dishwasher Repair)
by John Hensler 6/23/2009 1:02:16 PM(UTC)
by leland48 4/15/2009 7:32:25 AM(UTC)
GE dishwasher leak - not the usual suspects! (Dishwasher Repair)
by pennypickers 3/24/2009 6:04:25 PM(UTC)
GE Dishwasher Leaking from fitting below washer arm (Dishwasher Repair)
by DeG6 11/25/2008 11:59:59 PM(UTC)
GE dishwasher leaking (Dishwasher Repair)
by Chuck Hamby 11/9/2008 10:33:16 AM(UTC)
