| » Very Strange Dishwsher |
Model Number: GSD3000w20 Brand: GE Age: 5 - 10 years
I start the dishwasher and it starts fine .then maybe 5to 10 min. it stops and starts beeping the display window says that the lower spray arm is blocked so i look inside to make sure nothing is blocked.start the washer agine 5min apr. it stops again. nothing is blocking the arm. so i took out the bottom rack and it still stopand the reading said blooked arm. Got any ideas what is going on thanks for your help.
There is a temperature sensing item in the dishwasher control panel that is probably sensing low water temperature.
Try increasing the water temperature and see if that fixes it. Temperature needs to be at least 120 degrees. Also, check for clogged holes in the lower spray arm.
__________________
Quote:
Try setting the hot water temperature to 130 degrees. Also, time the drain time and post results, should be a bit less than 40 seconds with a full load of tub water just under the heater.
__________________
| Display Modes | |
| LG Dishwsher LDS5811WW IE Drain Error Message | aylwardg | Dishwasher Repair | 0 | 12-24-2009 11:31 AM |
| Strange Washer | dirtyhat62 | Washer Repair | 2 | 04-16-2009 07:41 PM |
| Dishwsher partial drain problem | christydishwasher | Dishwasher Repair | 1 | 08-30-2008 08:13 AM |
| strange noise | pygoodman | Refrigerator & Freezer Repair | 1 | 04-27-2008 04:46 PM |
