| » Kitchen Aid - Starts, Fills, Drains, Heats |
Please try to locate the model number.
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
Check your spray arms & supply lines for an obstruction.
nat
__________________
Check underneath the unit , there is a round silver start capaciter on the left side, turn power off to unit, pull front kick panel. and reach straight back with a good flashlight to see as you reach behind the back of the pump assembly, you should see or feel a blue and a yellow wire each on its on terminal.
checking breakdown
__________________
Quote:
There is a round silver capacitor as shown in photo. I can see a yellow wire, however I can not see the blue wire. I assume I am on the right item. Anyway, what are you suggesting? Do you believe it should be replaced? |
I'm sorry I wasn't clear, I wanted you to check physically with your hands that both wires were attached, either one being off or loose would prevent the motor from operation, besides that, I think you have a bad motor. Check your Use and Care manual most motor pump assemblys carry an extended warranty on replacement
Quote:
Thank you. I will check that. Otherwise I will be buying new motor assembly and installing. Thanks Jeff |
| Display Modes | |
| fills and drains at the same time | bidd6 | Washer Repair | 4 | 11-27-2008 11:17 AM |
| Bosch dishwasher fills, drains, fills again then stops | ricsan | Dishwasher Repair | 1 | 06-05-2008 03:40 AM |
| fills and drains right out | cherylmay | Washer Repair | 4 | 05-29-2008 02:48 AM |
| fills up and drains immediately | dennis b | Washer Repair | 3 | 12-14-2007 11:41 AM |
| Fills and drains......no spin | danc44 | Washer Repair | 5 | 12-01-2007 07:49 PM |
