Appliance Repair Forum
-   Dishwasher Repair (http://forum.appliancepartspros.com/dishwasher-repair/)
-   -   pots and pans and normal lights blinking! (http://forum.appliancepartspros.com/dishwasher-repair/122481-pots-pans-normal-lights-blinking.html)
luebe 09-07-2010 01:14 PM
please help i have tryed everything...when i flip the breaker and come in here and press sani rinse and heated dry to try to get in diagnosed mode it hasnt worked...does anyone know how else u can get it into hat mode or to reset it?the normal and pots and pan are flashing back and forth right now and sometimes the cancel button works.....please help
Joe / APP Team 09-07-2010 01:52 PM
Quote:
Luebe,
You most likely have a bad touchpad assembly, and will need to replace it.
Part number: AP4310681
I have attached the technical datat sheet, so you can run the touchpad and diagnostic tests, so you can varify the operation of the machine.
http://www.servicematters.com/docs/w...0W10082651.pdf
Good Luck,
