Discuss
Pump impeller removal
 in
Dishwasher Repair
How Is The Impeller ( Item 24 ) On The Diagram Removed. Is It Pressed On The Shaft Or Threaded?
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Pump impeller removal
  #1 (permalink)
Old 09-23-2008, 05:02 AM
Junior Member
steveb123 is on a distinguished road
Default Pump impeller removal
Model Number: GU980SCGB3   Brand: Whirlpool   Age: More than 10 years
Ads By Google
Related Models
Whirlpool GU980SCGB3
Whirlpool GU980SCGQ0
Whirlpool GU980SCGQ1
Whirlpool GU980SCGQ2
Whirlpool GU980SCGQ3
Whirlpool GU980SCGS1
Whirlpool GU980SCGS2
Whirlpool GU980SCGS3
Whirlpool GU980SCGT2
Whirlpool GU980SCGT3
Whirlpool GU980SCGZ0
Whirlpool GU980SCGZ1
Whirlpool GU980SCGZ2
Maytag GV1110PRW Range - F/s Std Gas
International GV1226NXEW Freezer - Vertical
International GV1726NXEW Freezer - Vertical
Hoover GV3177WUA Range - F/s Std Gas
Hoover GV3177WUA5 Range - F/s Std Gas
Hoover GV3177WUW Range - F/s Std Gas
Hoover GV3177WUW5 Range - F/s Std Gas
Maytag GV3277XUA Range - F/s Std Gas
Maytag GV3277XUW Range - F/s Std Gas
Hoover GV3531WUA Range - F/s Std Ele
Hoover GV3531WUW Range - F/s Std Ele
Whirlpool GVW9959KL0
Whirlpool GVW9959KL1
Whirlpool GVW9959KL2
Whirlpool GVW9959KL3 Automatic Washer
Whirlpool GVW9959KQ0
Whirlpool GVW9959KQ1
Whirlpool GVW9959KQ2
Whirlpool GVW9959KQ3 Automatic Washer
Whirlpool GVW9959KT0
Whirlpool GVW9959KT1
Whirlpool GVW9959KT2
Whirlpool GVW9959KT3 Automatic Washer
Maytag GW18F1 Washer - Top Loading
Maytag GW18F1A Washer - Top Loading
Maytag GW18F1H Washer - Top Loading
Maytag GW18F1W Washer - Top Loading
Maytag GW18F2 Washer - Top Loading
Maytag GW18F2A Washer - Top Loading
Maytag GW18F2H Washer - Top Loading
Maytag GW18F2W Washer - Top Loading
Maytag GW18G1 Washer - Top Loading
Maytag GW18G100 Washer - Top Loading
Maytag GW18G124 Washer - Top Loading
Maytag GW18G125 Washer - Top Loading
Maytag GW18G1A Washer - Top Loading
Maytag GW18G1HW Washer - Top Loading
Maytag GW18G1WW Washer - Top Loading
Maytag GW20F6 Washer - Top Loading
Maytag GW20F600 Washer - Top Loading
Maytag GW20F624 Washer - Top Loading
Maytag GW20F625 Washer - Top Loading
Maytag GW20F6A Washer - Top Loading
Maytag GW20F6H Washer - Top Loading
Maytag GW20F6W Washer - Top Loading
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0
Whirlpool GW395LEGB1
Whirlpool GW395LEGB3
Whirlpool GW395LEGB4
Whirlpool GW395LEGB5
Whirlpool GW395LEGB6
Whirlpool GW395LEGQ0
Whirlpool GW395LEGQ1
Whirlpool GW395LEGQ3
Whirlpool GW395LEGQ4
Whirlpool GW395LEGQ5
Whirlpool GW395LEGQ6
Whirlpool GW395LEGT3
Whirlpool GW395LEGT4
Whirlpool GW395LEGT5
Whirlpool GW395LEGT6
Whirlpool GW395LEGZ0
Whirlpool GW395LEGZ1
Whirlpool GW395LEGZ3
Whirlpool GW395LEPB00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPB05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPQ05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS00 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPS05 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT00 30" Slide - in Gas Oven Non - Convect
Whirlpool GW395LEPT01 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT02 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT03 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT04 30" Slide - in Gas Oven Non - Conv
Whirlpool GW395LEPT05 30" Slide - in Gas Oven Non - Conv
Maytag GWC202 Dishwasher - Convertible
Maytag GWC204 Dishwasher - Convertible
General Electric GWR03AAMABB Refrigerator
Gibson GWS1149AS0 Washer - Gibson
Gibson GWS1149AS1 Washer - Gibson
Gibson GWS1339CS0 Gibson/washer
Gibson GWS1339CS1 Gibson/washer
Gibson GWS1749AS0 Washer - Gibson
Gibson GWS1749AS1 Washer - Gibson
Gibson GWS1749CS0 Gibson/washer
Frigidaire GWS223RFS0 Gib(v0) / Washer
Frigidaire GWS223RFS1 Gib(v0) / Washer
Frigidaire GWS223RHS0 Gib(v0) / Washer
Frigidaire GWS223RHS1
Frigidaire GWS445RFS0 Gib(v0) / Washer
  #2 (permalink)
Old 09-23-2008, 01:06 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
It is pressed on but due to water leak and rust many times it's not possible to pull it out. I usually used a chisel to break it in pieces.
Here are the break down diagrams for the Whirlpool dishwasher Model GU980SCGB3
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 09-23-2008, 01:27 PM
Junior Member
Default
Thank you. I guess there is a sl=pline or a flat on the shaft. Do I need to replace the seal under this? It is not leaking but I guess it would be a good idea while I am into it. Can this can be gotten from the top? Or do I need to remove the motor?
  #4 (permalink)
Old 09-23-2008, 02:26 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
One of seals is a part of this impeller. If you are going to break it then you have to replace all seals and impellers. Just buy a drain and wash impeller kit and follow the installation instructions included in the kit.
Some time it could be done from the top and some time not. It's hard to predict.
- The part number for the drain and wash kit is AP3115180
__________________
  #5 (permalink)
Old 07-14-2012, 10:44 AM
Junior Member
JAB1999 is on a distinguished road
Default impeller that is difficult to remove
Once the front cap of the pump body is unscrewed (RH threads), the brass top of the impeller assy. can be removed with vise grips and a hammer. Use a Dremel tool with either a saw or cutter wheel to cut around the impeller shaft
at several depths. After each cut remove the top section. Once you are below the flats on the shaft the impeller should turn freely and can be lifted out. The chisel method is OK, but care must be taken not to damage the pump body or motor housing (plastic).
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
How do I remover motor/pump/impeller wmako Dishwasher Repair 4 02-13-2010 06:11 AM
How to access pump/impeller h2onxs Dishwasher Repair 1 10-08-2009 09:36 PM
How Do I Remove Impeller from Pump bseiter Dishwasher Repair 0 06-23-2009 10:20 PM
whirlpool pump impeller osage885 Dishwasher Repair 0 01-10-2009 02:26 PM
Whirlpool dishwasher impeller removal wonderdog Dishwasher Repair 1 09-20-2008 11:18 AM
