| » kenmore 665 can only select "quick cycle" |
Model Number: 665-15953000 Brand: -brand- Age: Less than 1 year
just recently my Kenmore 665 stop worked properly, the control panel will only allow us to select the "quick" cycle. No other cycle will light up when the buttons are pressed and the quick cycle is useless for cleaning dishes.
Assuming it is the control panel what is involved in replacing it? thanks Ben Ads By Google Related Models |
Ben,
You will have to partially disassemble the door to replace the control board. pretty easy to do. Nat
__________________
-We don't have a fancy website but, we do have fast reliable service in South Central Missouri & do warranty work for Whirlpool, Estate, Maytag, Amana, Frigidaire, Gibson & more. We service most of the South Central Ozarks region. Send us an email at libertyapplservice@yahoo.com We are also Ministers that do a weekly jail house ministry. Rate Liberty Appliance Service on MyPros.com |
If you have your wiring diagram there should be a test proceedure listed for testing the ribbon cable, to make sure it's feeding power thru it. If no diagram them using an ohm meter you can start at one side of the cable and test each pin for continuity while pushing each button. Very time comsuming.
Nat
__________________
Is the unit less than a year old?
__________________
If you have a kick plate it should be attached there or inside the control panel.
Nat
__________________
Yopu can get just the parts you need too you don't have to prchase the whole assembly unless needed (about $100) Repair vs. Replacement is generally a personal call. I tend to fix as opposed to replace.
Nat
__________________
ok so i took the control touch panel apart this morning, the ribbon cable the goes all along the front for the buttons has 4 burnt point which is exactly the amount of buttons that dont work. apparently the ribbon cable and the whole button assembley are all one piece glued into the panel does anyone know if you can replace just the ribbon cable/buttons and not the entire front panel??
| Display Modes | |
| Kenmore Dryer "Auto" Cycle trouble | davidkochct | Dryer Repair | 1 | 07-09-2009 07:23 PM |
| Stuck on "Quick Wash" | pblkbrn | Dishwasher Repair | 1 | 06-15-2009 05:07 PM |
| Stuck on "Quick Wash" | pblkbrn | Dishwasher Repair | 1 | 06-15-2009 05:06 PM |
| Gallery Series ""Water Wont Go In"" | juancruz | Washer Repair | 1 | 04-28-2009 06:06 PM |
| Only freezes in "quick freeze" mode | alraybonsue | Refrigerator & Freezer Repair | 0 | 09-23-2007 07:10 PM |
