Discuss
leaking around pump shaft?
 in
Dishwasher Repair
Hi all, I have a maytag 2400awe that appears to be leaking from around the pump shaft? It is a
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » leaking around pump shaft?
  #1 (permalink)
Old 09-04-2010, 04:03 PM
Junior Member
gentry74 is on a distinguished road
Default leaking around pump shaft?
Model Number: maytag2400awe   Brand: Maytag   Age: 5 - 10 years
Hi all, I have a maytag 2400awe that appears to be leaking from around the pump shaft? It is a slow drip that occurs only when the pump is spinning. I saw another post of someone asking about how to remove the impeller. My question: is that what I need to replace? the impeller? Are there other parts I should order as well? I just want to make sure I purchase everything I need to complete the job. Differing opinions on what needs to be replaced are welcome too! Thanks in advance.
Ads By Google
Related Models
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
Maytag MBF2256HEW REF - BOTTOM MOUNTS
Maytag MBF2256KEB REF - BOTTOM MOUNTS
Maytag MBF2256KEB11 REFRIGERATOR
Maytag MBF2256KEB2 REFRIGERATOR
Maytag MBF2256KEB3 REFRIGERATOR
  #2 (permalink)
Old 09-05-2010, 08:49 AM
Junior Member
Smile resolved
I figured out how to slide the impeller off the shaft. The shaft is fluted. I was able to pull it straight off (though it was very tough). Rather than buying the 30.00 part, I carefully filled the area inside the gasket and around the shaft with liquid gasket (auto part). There was some hair and maybe a piece of dental floss (? just bought this house...) around the impeller shaft too. Cleaned everything up and tightened everything and the leak is gone. Anyone else who needs to do this--- you have to remove the housing from the washer and the motor from the housing (which requires removal of the impeller). Good luck!
  #3 (permalink)
Old 09-09-2010, 08:52 AM
Junior Member
LoveLearn is on a distinguished road
Default
You are to be commended for your clear thinking and directly effective repair approach. If I'd read this before you'd reassembled that pump motor-pump assembly, I would have suggested that you replace the original rust-prone motor wet-end armature-support bearing with a stainless steel bearing. Not free but available for about $8. Size is identical to that commonly found supporting rollerblade wheels. These pump seal leaks are sadly common. The usual result is wetting that single wet-side motor shaft support bearing, starting a continually degrading process which first makes the circulation pump motor increasingly noisy and eventually locks up that bearing. Then people hear the motor "hum" loudly, trying to start but not being able to spin which spinning also drives that motor's air-flow impeller needed to dump heat from the motor windings. Then the windings heat up enough for the motor's thermal-overload sensor to trigger shut-down until it cools enough for that sensor to automatically reset, starting the same "hum" noise and burn-prevention shut-down cycle again.
You did 95% of the work needed to replace that rust-prone wet-end motor armature support bearing with a rust-immune bearing. If you ever have occasion to get into it again, I suggest that you swap in a stainless steel bearing before reassembing that pump motor/pump assembly.
John
  #4 (permalink)
Old 09-16-2010, 09:09 AM
Junior Member
Default @ lovelearn
If my memory is accurate, I cannot recall seeing a bearing anywhere during my disassembly/assembly. The plastic impeller (which was all one part) and the main housing/basin only had rubber washers permanently attached for the drive shaft. Can you elaborate on where the bearing is? Thanks very much for taking the time to respond. Much appreciated.
  #5 (permalink)
Old 09-16-2010, 10:40 AM
Junior Member
Default
Sorry, I've been pretty swamped with a prototype design project. I just got an email notice that you posted a question.
The pump's impeller is supported by the motor's exterior extended shaft. The motor shaft, on which the spinning armature is mounted, is supported on each end of the motor by a roller bearing set. The end of that motor which is closest to the pump is what I described as the motor's "wet end." While the extended shaft spins the pump impeller, that part of the shaft gets wet. But the pump seals are intended to prevent any of that water from seeping though to what is intended to remain a dry region, where the wet-end motor bearing spins. Unfortunately, pump seals eventually develop weeping seepage. When that happens, water can migrate over to the motor shaft support bearing. I know that it doesn't appear that it would get over that far. But after field experience has shown untold thousands of rust-failed motor support bearings, it seems pretty obvious that water can and does eventually wet that bearing. If that bearing is replaced with one which can't rust, the shaft can still rust, but that would take a long time to fail from rusting. The first part to fail is the seal, then the rustable bearing. They are already using good seals. Improving the seals may be tough. But using a bearing on that end of the motor which can't rust would be extremely easy during manufacture.
I'm suggesting that field replacement of those bearings is justified when the original rustable bearings fail due to water-contact-induced rusting.
I hope that clarifies my comments. Sorry that I failed to make that more clear in my earlier statement.
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Removing the push on nut on the drain pump shaft jdstewa Dishwasher Repair 0 08-18-2010 02:30 PM
Pump motor shaft part MrFixItAlready! Dishwasher Repair 1 07-22-2010 07:26 PM
Kenmore leaking at pump shaft, doesn't wash takoateli Dishwasher Repair 3 12-23-2009 10:53 PM
Whirlpool washer leaking drain pump stuck to motor shaft, how to separate to replace? ennemm Washer Repair 1 05-03-2009 01:03 PM
Dishwasher pump shaft not turning oxymoron Dishwasher Repair 2 03-01-2009 07:21 AM
