Above captioned unit when it starts cycle indicates a time of anything from 58 minutes to 116 minutes. Sometimes it heats the water for the cycle, and sometimes it does not, resulting in the dishes not being clean. Also, cannot find anything from Bosch other than the unit has been discontinued. Searched this site and found a manual that relates to SHU but not to 66, and the pictorial descriptions of the control module does not correspond to that which I have looked at in this unit. If you call the control module the apparatus behind that which indicates the cycle time, the plug for it is on the right side of the PC board, rather than what the picture on this site shows in that it appears to be at the upper right hand corner. Any thoughts as to what the problem is/what the part number is? Thanks for your help Dennis Dvorak posgudni@swbell.net
