torque_dwf
#1 Posted : Saturday, September 4, 2010 4:29:20 AM(UTC)
torque_dwf
Hi My GE Triton III GDS5260 dishwasher will not drain, this is what I have done so far:
1) Hoses are clear
2) Piston check valve assy thingy new
3) drain pump new
Took hose off exhaust outlet and ran a rinse/cancel, no pressure coming out of
outlet (just gravity drain) except just as washer finished cycle a brief shot of pressure.
Does this then indicate a sequence switch?
torque_dwf
#2 Posted : Saturday, September 4, 2010 7:03:10 AM(UTC)
torque_dwf
I just ran a test cycle per sheet I found wedged under dryer. If I skip through
to step 12 which runs the Aux drain motor for 75 sec it drains like a charm
what is stopping it from doing this during a normal cycle?
:confused:
I am running a normal wash empty right now.
Edited: OK ran regular wash cycle and I heard it drain into the sink on every cycle except the final rinse. I suspect the sequence switch but would love some way to confirm its not the control board cause they both cost 70+ bucks and I have already blown 70 on a pump I didn't need. Grrrr.
LoveLearn
#3 Posted : Thursday, September 9, 2010 8:07:43 AM(UTC)
LoveLearn
Your description sounds as though you've correctly identified the switching circuit as your machine's cause for not performing the final drain sequence.
Some dishwashers have a front panel button allowing manually triggering a drain cycle. If you do that when the wash sequence ends but before heating coil drying, you might be willing to live with that manual intervention step as a solution.
But I've seen heating coils operate over water-filled dishwasher sumps due to final drain failures like what you've described. The result is often lots of steam and water vapor production with poorly-dryed dishes. One with a black front and front air vent developed an unsightly white surface covering around that air vent. Anytime I see one of those, I immediately expect to find a drain system problem. After correcting the drain problem, cleaning the black plastic front with vinegar or another acid cleaner like Lime-a-way restores the clean black appearance.
More information for you. The choice of how to deal with it is yours.
John
Dishwasher wont drain - had new motor (Dishwasher Repair)
by brady5885 10/31/2015 9:51:05 AM(UTC)
Whirlpool dishwasher wont drain (Dishwasher Repair)
by JayTeeC 3/30/2014 1:53:15 PM(UTC)
by doanhtran@gmail.com 7/9/2012 7:50:20 PM(UTC)
by virg912 6/24/2012 6:55:23 AM(UTC)
by calla929 6/19/2012 4:28:22 PM(UTC)
Dishwasher wont drain (Dishwasher Repair)
by Randy Moore 5/13/2012 7:30:46 AM(UTC)
dishwasher wont drain even though solenoid engages (Dishwasher Repair)
by rafjr94 1/8/2012 2:47:20 PM(UTC)
Dishwasher Wont Drain. (Washer Repair)
by darfug 1/3/2012 2:06:41 PM(UTC)
Bosch Dishwasher wont drain after wash (Dishwasher Repair)
by ddzc 7/20/2011 1:56:49 PM(UTC)
Bosch dishwasher wont drain (Dishwasher Repair)
by dishwasherDave 10/7/2010 12:57:28 PM(UTC)
ge profile triton dishwasher wont drain (Dishwasher Repair)
by tstevens77 7/1/2010 11:49:22 AM(UTC)
Whirlpool Dishwasher wont drain water (Dishwasher Repair)
by shirump 5/30/2010 8:38:25 AM(UTC)
frigidaire dishwasher wont drain (Dishwasher Repair)
by imorrill2003 2/24/2010 12:46:19 PM(UTC)
by kmt12708 2/1/2010 7:13:22 AM(UTC)
by jhadz 1/14/2010 3:01:11 PM(UTC)
