| » Whirlpool dishwasher impeller removal |
Model Number: DU8000XX2 Brand: Whirlpool Age: More than 10 years
I have a Whirlpool dishwasher that has seen light use for 16 years. It has developed a leak between the pump housing and the motor shaft, but only during draining. I ordered a new housing, shaft seal, and seat. I have been successful in removing the Disk and Mount Assy (Item 10), but I'm at a loss at how to remove the impeller and its keeper (the latter resembles a cylindrical grinding stone bonded to the shaft).
At the same time, there is considerable rust around the shaft where it enters the pump housing on the motor side. A spring clip seems to retain something there (two halves of the shaft?), but it's too rusted to tell how it fits together. Since this is the point of the leak, I'm wondering whether I'll be able to get a good seal even if I can install the parts I've bought. A new pump and motor runs $145. Should I just pitch in for the whole assembly, or is it likely that I can repair this? If so, how do I get the impeller off? Or should I apply the $145 to a new dishwasher? This unit has been trouble-free, other than a water hammer that I've learned to put up with during filling. Ads By Google Related Models |
if you plan on getting anymore service out of a 16 year old dishwasher i would replace the whole assembly, that way you at least have a warranty. i dont like to do replacement parts on these units as i have had several leaks turn up a week later. you might want to inspect tub really close for rust before ordering parts. if you have rust around the flange the new one will probably leak too. hope this helps and good luck
| Display Modes | |
| Whirlpool/Kenmore dishwasher impeller replacement | richappy | Dishwasher Repair | 28 | 09-22-2012 10:46 AM |
| Pump impeller removal | steveb123 | Dishwasher Repair | 4 | 07-14-2012 10:44 AM |
| Broken Whirlpool impeller | kfernow | Dishwasher Repair | 0 | 08-04-2009 07:56 AM |
| whirlpool impeller seal | rjneill | Dishwasher Repair | 1 | 05-14-2009 11:36 AM |
| Whirlpool impeller | ea3898 | Dishwasher Repair | 1 | 01-28-2009 06:17 PM |
