PLEASE HELP! i HAVE A KENMORE SERIES 90 DRYER. IT DOES NOT HEAT, BUT THE DRUM ROTATES. I REMOVED THE GAS ASSEMBLY AND CHECKED THE IGNITOR, IT WORKS OK (TURNS RED HOT) I SUSPECT ONE OF THE COILS THAT ARE IN THE GAS VALVE, BUT DON'T KNOW HOW TO TEST THEM. I'M TRYING TO SAVE MONEY IF I CAN BY NOT BUYING THE ENTIRE ASSEMBLY. ALSO WHERE CAN I FIND THE THERMOSTAT? IS IN THE SAME TUBE AS THE IGNITER? YOUR HELP WOULD BE GREATLY APPRECIATED!
SIGNED "OUT OF GAS'' P.S. IT'S A GAS DRYER
