My dishwasher sometimes drains all the water out shortly after the cycle starts, then continues to run dry until the next cycle. It will then fill and start again, sometimes it does the same thing on the next cycle too. It is a sporadic problem but getting worse. I looked at a parts breakdown and found a "drain pump" and a "drain pump flapper", but nothing like a drain valve. Is the drain valve incorporated into the drain pump?
