| » Washer won't drain |
Model Number: WFW8300SW02 Brand: Whirlpool Age: 1 - 5 years
I took apart the drain hose, cleaning it out. I cleaned out the pump. There was lots of lint and pennies, I may have burned up the pump or motor since it was filled with gunk. Is it likely a new pump / motor #AP4308966 will fix my washer. (it starts washing but won't drain giving a error code of F-21)It costs about 68.00
Here is the parts breakdown
Replacement parts for WHIRLPOOL WFW8300SW02 Automatic Washer | AppliancePartsPros.com Here is the tech sheet http://www.servicematters.com/docs/w...0W10071760.pdf You could try diagnostics, Or Unplug the unit and pump and measure it for resistance. If infinite resistance (open), it needs replacing Or Check for voltage at the pump when it should be running. If you have 120 volts and it is not running, it is toast Or Remove it from the unit, hook it up to a line cord and see if it will run.
__________________
| Display Modes | |
| My Hotpoint washer won't drain or spin, but it will if I drain the hose by gravity? | ks_becker | Washer Repair | 0 | 08-10-2010 10:25 AM |
| Washer Won't Drain | iforbes | Washer Repair | 1 | 06-17-2010 05:17 PM |
| Washer won't drain | dfarrington@bmcwest.com | Dishwasher Repair | 2 | 10-05-2009 05:44 AM |
| washer won't drain | david.l.kessler | Washer Repair | 2 | 12-19-2008 08:28 AM |
| Calypso Washer Washer Won't Drain | SamB | Washer Repair | 3 | 11-27-2007 01:41 PM |
