Discuss
Maytag MDBH945AWW drips under float switch
 in
Dishwasher Repair
smckech1972 analysis lead me to my solution. I have a Maytag QuietSeries 300, MDB8601AWW10689934l, with the tub being a single
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Maytag MDBH945AWW drips under float switch
  #11 (permalink)
Old 04-10-2018, 07:51 PM
Junior Member
Bill1 is on a distinguished road
Default Maytag QuietSeries 300 leaks at float
I have a Maytag QuietSeries 300, MDB8601AWW10689934l, with the tub being a single mold unit with the float located on the front right, leaking at the float assembly under the tub.
The float extends through the tub resting on the float switch.
An Ohms check of float switch was positive (good)
However, drips of water (often a small stream of water) was leaking at the float\switch.
Steps taken:
Removed float and cleaned gunk under the "cap"
Re-installed float
Ran rise cycle - okay no leaking
Ran wash cycle with encapsulated dishsoap product
Water on floor. Float leaking
Filled liquid "jet dry" reservoir with white vinegar and poured 1 cup in tub
Started dishwasher on Auto Clean High Temp
Drip, drip, drip
Opend door to observe soap suds in tub
Let cycle complete
Next I poured a cup of liquid CLR into the tub followed with 3 cups of hot tap water
Started dishwasher on Heavy Wash, Tough Scrub, High Temp cycle
After tub filled with water
Drip, drip
Opened door, lots of suds
Closed door, cycle resumed
Time goes on
Drips slowed
Opened door less suds observed
Time goes on
Drips slowed
Drip stopped
Next I poured a second cup of CLR into the tub followed with 3 cups of hot tap water
Drip, drip
Let cycle continue
Opened door, suds
Time goes on
Drips slowed
Opened door, less suds
Time goes on
Drips stopped
Not comfortable
Poured what was left of CLR
Drip, drip
Opened door, suds
Time goes on
Drips slowed
Let cycle complete
Poured 1 cup of white vinegar in tub with 3 cups of hot tap water
No Drip
Opened door, no suds
Let cycle complete
No Drip
Let cycle complete
Really did not want to disassemble the dishwasher
Many cycles of cleaning, saved $300 on a new dishwasher
  #12 (permalink)
Old 04-12-2018, 07:45 AM
Junior Member
ronakshah2000 is on a distinguished road
Default
Just a followup - my fix solved my problem. About 1-2 years later I replaced with a kitchenaid as the JennAir just didn't clean well (and never really had). Love the KitchenAid.
Last edited by ronakshah2000 : 04-12-2018 at 07:47 AM. Reason: Realized I had already detailed my solution a while ago
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Lid Switch Steph1 Washer Repair 1 02-04-2010 05:26 PM
Bosch dishwasher float switch Steve A Dishwasher Repair 14 10-12-2009 07:33 PM
Kenmore 665 Leaking from float switch hw737 Dishwasher Repair 0 10-06-2009 03:10 PM
maytag lid switch benjakiah Washer Repair 3 02-03-2008 06:17 PM
How to remove overfill switch float Davejb Dishwasher Repair 0 01-21-2008 01:35 PM
