1957pickup
#1 Posted : Monday, September 8, 2008 6:00:55 PM(UTC)
1957pickup
The control panel went blank and the handle had no tension with the door closed. I opened the door and the handle was broken, I replaced the handle but there is still nothing happening on the control panel. I checked power going into the latch assembly and it was there. I had power going to the latch assembly from the black wires and power going through the switch until I connected th pinkish wires going into the other side of the latch assembly, then I only had power on the black side. Bad latch assembly????? Thanks in advance!!!:)
libertyappl
#2 Posted : Monday, September 8, 2008 7:02:03 PM(UTC)
libertyappl
With looking at your wiring diagram, the pink wire goes from the control board to the turbidity sensor, not to the door latch.
Nat
GE Side by side fridge; control panel blank; not cooling (Refrigerator & Freezer Repair)
by peteror 3/20/2022 10:14:32 PM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
single oven, control panel blank/dead (Oven Repair (including Ranges and Cooktops))
by walkertx 1/2/2011 9:23:55 AM(UTC)
Maytag CRE8600CCE electric stove control panel blank (Oven Repair (including Ranges and Cooktops))
by ropat 9/22/2009 2:45:38 PM(UTC)
