My sink drain backed up into the dishwasher. After clearing the drain, I turned on the dishwasher, which pumped out the water, but now the pump won't stop. I tried the cycle cancellation, but that doesn't stop it. I can turn off by on/off switch or opening door. Pump still runs when I turn the machine back on.
I am also having the control panel (2H) issue and plan to fix that as soon as I get the pump problem fixed.
Is there a relay that might be stuck or some way to reset this?
