Gas dryer heats then stops heating
Dishwasher Repair
I know you guys have answered this for other models but I just want to verify my thoughts and get
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Gas dryer heats then stops heating
  #1 (permalink)
Old 09-04-2008, 07:20 PM
Junior Member
tdl340 is on a distinguished road
Default Gas dryer heats then stops heating
Model Number: 110.74963200   Brand: Kenmore   Age: 5 - 10 years
I know you guys have answered this for other models but I just want to verify my thoughts and get the correct part numbers. My dryer will fire up when cool, then does not fire up again until I shut it off and wait a while. I cleaned every bit of lint out of the machine. I have continuity accross the thermal fuse. When I watch the igniter it glows every couple of minutes but the burner does not ignite after the inital ignition. From all the theads I have read it appears to be the gas valve coils. Does this sound reasonable and if so are the parts available for my dryer on this site as Sears wants around 35 dollars apiece. Ones that I have seen on this site are in a kit and much cheaper.
Thanks for any help
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 12-30-2009, 01:10 PM
Junior Member
BenThere is on a distinguished road
Default Dryer heats for one minutes then stops heating
I have tried allot of troubleshooting, ohm readings ok on coils, disconnected the flame sensor lead, clean all the lint, then finally after reading two other posts, I replaced the coils on the gas valve and all is ok. To change the coils , unplug the dryer, see below for open cabinet. Two coils are on the gas valve. Carefully disconnect the two pull wire connectors from each coil. Take out two philips screws in the bracket. Remove the coils. Replace the coils, small and larger coils. Small pin aligns the coils in the bracket and replace the screws and connectors. Cost about $25. There was lint in the gas tube air slots. I have a MAGIC CHEF YG20JN5, LP gas dryer, it is 19 yrs old. I have replaced the belt, rollers, slip pads, blower cage, and now the coils. It has a lint screen in the lower front door. It keeps going. To open the top, I push on the two clips about 4 inches from the side in the front top crack. Lift the top and rotate back out of the way. Remove two screws inside top front left and right corners. Disconnect two metal clips that hold the wires for the door switch. Lift the front panel up off the two bottom catches. Rotate front panel out of the way. Now there is access to the blower, gas valve, etc. This is give back for info I received, saved me the cost of new dryer.
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
gas dryer heats then stops heating tomg19 Dryer Repair 2 01-02-2016 01:20 PM
Whirlpool gas dryer heats then stops heating? Need Help! cdpken Dryer Repair 5 09-27-2011 08:13 PM
Dryer heats then stops heating eymuller Dryer Repair 0 05-07-2009 04:25 PM
Dryer heats up then stops heating Art C. Little Dryer Repair 0 04-24-2009 06:17 AM
dryer heats for 5 min then stops heating shane010122 Dryer Repair 0 04-20-2009 05:20 PM
