My dishwasher wont drain completely. There is water left behind a few inches deep at the bottom after each cycle. I checked the drain tube which is not blocked. I also removed the cover inlet and there was no debris to remove. I also let the dishwasher fill and tried to use the reset button but the water did not drain. Any suggestions.
