Norm Conner
#1 Posted : Monday, September 1, 2008 9:55:53 AM(UTC)
Norm Conner
Hi
I have a GE dishwasher that is not draining completely. After the washing cycle is complete, the water level in the bottom of the dishwasher is covering the heating element. I did replace the pump and motor assembly in March 2008 because the shaft seal was leaking. I did purchase the assembly from your company. I don't know if the water drainage was going on before the pump was changed. I just purchased the home in January, and the first time I used the dishwasher I discovered the pump was leaking. What do you think the problem may be? You can call me or e-mail me @ (253) 223-1554 or Normconner@aol.com. Thank you very much for your help, Norm Conner
misterfixall
#2 Posted : Monday, September 1, 2008 4:32:05 PM(UTC)
misterfixall
problem may be with piston+nut. or drain pump solonoid or blockage under sink where drain hose connects or else where
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Bosch Dishwasher SHE3ARF6UC/22 E15 Error (Dishwasher Repair)
by codyace 3/29/2024 11:51:41 AM(UTC)
GE dishwasher GDT695SSJ0SS middle arm not spinning (Dishwasher Repair)
by merrittjr 3/23/2024 10:51:00 AM(UTC)
Bosch Dishwasher Display Goes Out After Latching Door (Dishwasher Repair)
by Guest 3/11/2024 7:00:18 PM(UTC)
Kenmore 90 665 dishwasher noise from impellor (Dishwasher Repair)
by Guest 3/10/2024 12:30:08 PM(UTC)
LG dishwasher bE Bubble Error (Dishwasher Repair)
by Guest 2/13/2024 10:58:29 AM(UTC)
Frigidaire dishwasher 2nd water inlet valve fails (Dishwasher Repair)
by Guest 2/13/2024 3:32:15 AM(UTC)
Dishwasher fills and drains only. Does not go through the wash and rinse cycle (Dishwasher Repair)
by Guest 2/11/2024 6:26:48 AM(UTC)
Maytag dishwasher model MDB4949SKZ1 (Dishwasher Repair)
by thepontif 2/3/2024 11:15:46 AM(UTC)
#DW80F600UTS Samsung Dishwasher High Temperature Heating Error (Dishwasher Repair)
by Guest 1/24/2024 6:35:24 AM(UTC)
GE Dishwasher GDF620HMJ2ES (Dishwasher Repair)
by lou@officenerd.com 1/14/2024 3:32:20 PM(UTC)
Clean light flashing 7 times: dishwasher run (Dishwasher Repair)
by Guest 1/14/2024 9:56:27 AM(UTC)
KDTE554CSS3 Dishwasher (Dishwasher Repair)
by olderwhite@yahoo.com 1/13/2024 10:34:56 AM(UTC)
Dishwasher electrical help (Dishwasher Repair)
by Guest 1/11/2024 4:35:37 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
