Discuss
dishwasher draining all the time
 in
Dishwasher Repair
It seems to be draining all the time. It adds water like it is supposed to, the water will just
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » dishwasher draining all the time
  #1 (permalink)
Old 09-18-2007, 09:53 AM
kevintooley kevintooley is offline
Junior Member
kevintooley is on a distinguished road
Default dishwasher draining all the time
Model Number: du55ca-01   Brand: Magic Chef   Age: More than 10 years
It seems to be draining all the time. It adds water like it is supposed to, the water will just start coming out the sprayers, then the drain solonoid assembly starts working, draining for a few seconds, then not draining for a few seconds, then back to draining. Is this solonoid bad? At first i thought it was the level switch, but i dont think so now as it does let water in.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 09-19-2007, 07:02 PM
Matt / APP Team Matt / APP Team is offline
Administrator
APP Team
Matt / APP Team is on a distinguished road
Default
Click for parts breakdown.
There is a solenoid under the dishwasher that changes the pump from wash to drain. Try moving the arm that opens and closes the valve by hand, it could be stuck and once broken free it may work. Also check the return spring isnt damaged. Also make sure the float for the water level isnt stuck in the up position.
Click for drain solenoid kit.
If the solenoid is getting voltage at all time then it could be the timer is sending voltage at all times.
Click for timer.
If it is the timer you may want to think twice about spending $150.00 on a 10yr+ dishwasher.
__________________
Those who don't learn from history are doomed to relive it!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
no draining after washing. luirod563 Washer Repair 4 10-12-2007 09:38 AM
front loader not draining distress Washer Repair 1 09-14-2007 03:24 AM
Water Is Draining As It Fills jbgreer Washer Repair 2 09-03-2007 11:52 AM
no time wallace Dishwasher Repair 0 08-22-2007 04:00 PM
Clock Loses Time Dangermouse Oven Repair (including Ranges and Cooktops) 1 08-15-2007 05:25 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
