Discuss
How to remove door cover to check switch
 in
Dishwasher Repair
My dish washer quit running. I was able to get it to run briefly by pushinhg the ON/OFF switch repeatedly
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » How to remove door cover to check switch
  #1 (permalink)
Old 08-29-2008, 06:58 PM
Junior Member
AZEERAK is on a distinguished road
Default How to remove door cover to check switch
Model Number: SMU 4056 UC/14   Brand: Bosch   Age: 5 - 10 years
My dish washer quit running. I was able to get it to run briefly by pushinhg the ON/OFF switch repeatedly once, but it quit the next time after opening the door and closing it again.
I suspect the ON/Off switch but can't open the cover to get to it. I have removed the three phillips small screws on each side the holds down the side strips but It did not help in removeng the cover. I dont see any pop up covers that may be concealing screws either. Please Help. Thanks
Ads By Google
Related Models
Bosch SMU2042 UC/09 (FD 7307-7504)
Bosch SMU2042 UC/09 (FD 7505-7902)
Bosch SMU2042 UC/13 (FD 7312-7504)
Bosch SMU2042 UC/13 (FD 7505-7902)
Bosch SMU2042 UC/14 (FD 7402-7504)
Bosch SMU2042 UC/14 (FD 7505-7902)
Bosch SMU2046 UC/09 (FD 7307-7902)
Bosch SMU2046 UC/13 (FD 7312-7902)
Bosch SMU2046 UC/14 (FD 7402-7902)
Bosch SMU3032 UC/14 (FD 7507-7902)
Bosch SMU3036 UC/14 (FD 7507-7902)
Bosch SMU4052 UC/09 (FD 7307-7902)
Bosch SMU4052 UC/14 (FD 7402-7902)
Bosch SMU4052 US/01 (FD 7106-7308)
Bosch SMU4052 US/08 (FD 7203-)
Bosch SMU4052 US/09 (FD 7210-)
Bosch SMU4056 UC/09 (FD 7307-7902)
Bosch SMU4056 UC/14 (FD 7402-7902)
Bosch SMU4056 US/01 (FD 7106-7308)
Bosch SMU4056 US/09 (FD 7211-)
Bosch SMU4092 UC/14 (FD -7902)
Bosch SMU4096 UC/14 (FD -7902)
Bosch SMU7052 UC/09 (FD 7307-7504)
Bosch SMU7052 UC/09 (FD 7505-7506)
Bosch SMU7052 UC/09 (FD 7507-7902)
Bosch SMU7052 UC/14 (FD 7402-7902)
Bosch SMU7052 UC/14 (FD 7507-7902)
Bosch SMU7052 US/02 (FD 7106-7308)
Bosch SMU7052 US/09 (FD 7210-)
Bosch SMU7056 UC/09 (FD 7307-7504)
Bosch SMU7056 UC/09 (FD 7505-7506)
Bosch SMU7056 UC/09 (FD 7507-7902)
Bosch SMU7056 UC/14 (FD 7402-7902)
Bosch SMU7056 UC/14 (FD 7507-7902)
Bosch SMU7056 US/02 (FD 7106-7308)
Bosch SMU7056 US/09 (FD 7210-)
Maytag SMV9165BC Mwave - Mounted Over Range/wo
Maytag SMV9165CC Mwave - Mounted Over Range/wo
Maytag SMV9165SC Mwave - Mounted Over Range/wo
Maytag SMV9165WC Mwave - Mounted Over Range/wo
Thermador SMW272B
Thermador SMW272P
Thermador SMW272S
Thermador SMW272W
Thermador SMW272YB AFTER S/N 8204
Thermador SMW272YS AFTER S/N 8204
Thermador SMW272YW AFTER S/N 8204
Thermador SMW272ZS AFTER S/N 8204
Thermador SMWS72YP AFTER S/N 8204
Bosch SMZ3022
Bosch SMZ3044
Bosch SMZ3055
Bosch SMZ3077
Bosch SMZ3088
Whirlpool SN
Amana SNAC-700.A Commercial Microwaves
Amana SNAC-700.B Commercial Microwaves
Amana SNAC-7TP.A Commercial Microwaves
Amana SNAC-7TP.B Commercial Microwaves
Amana SNAC700 Commercial Microwaves
Amana SNAC700.C Commercial Microwaves
Amana SNAC700.D Commercial Microwaves
Amana SNAC7TP.003 Commercial Microwaves
Amana SNAC7TP.004 Commercial Microwaves
Amana SNAC7TP.005 Commercial Microwaves
Amana SNAC8LW Commercial Microwaves
Amana SNE26AA Range - Electric Std Delaware
Amana SNE26CB Range - S/c S/i Ddraft Gas
Amana SNE26ZZ Range - S/c S/i Ddraft Gas
Whirlpool SNFGA
Amana SNK26AA Range - S/c S/i Ddraft Gas
Amana SNK26AA0 Range - S/i Std Gas
Amana SNK26AA5 Range - S/i Std Gas
Amana SNK26CB Range - S/c S/i Ddraft Gas
Amana SNK26CB0 Range - S/i Std Gas
Amana SNK26CB5 Range - S/i Std Gas
Amana SNK26FS Range - S/c S/i Ddraft Gas
Amana SNK26FS0 Range - S/i Std Gas
Amana SNK26FS5 Range - S/i Std Gas
Amana SNP26AA Range - S/i Std Gas
Amana SNP26AA0 Range - S/i Std Gas
Amana SNP26AA5 Range - S/i Std Gas
Amana SNP26AH0 Range - S/i Std Gas
Amana SNP26CB Range - S/i Std Gas
Amana SNP26CB0 Range - S/i Std Gas
Amana SNP26CB5 Range - S/i Std Gas
  #2 (permalink)
Old 08-30-2008, 01:26 PM
Junior Member
Default
I was able to open the door. Since I don't have a wiring diagram I am not sure what is normal for these switches. The ON/OfF sw has 4 wires on slide connectors that closes between two opposing wire pairs when the sw is in the On mode. When voltage is applies one contact gets 21V and the other about 10V. Did not see any obvious sign of a problem and the disch washer would not start.
Any ideas? Help please! Thanks
AZ
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
remove timer cover and damper cover fle Refrigerator & Freezer Repair 1 02-09-2010 05:23 PM
removal of front cover to check fuse guytq18 Microwave Repair 0 12-17-2009 11:57 PM
remove top cover MikMac Dryer Repair 3 05-15-2009 10:43 AM
Remove cover from cooktop PartlyCloudy Oven Repair (including Ranges and Cooktops) 1 04-19-2009 08:58 AM
remove freezer door ice/water cover assembly jtwusc Refrigerator & Freezer Repair 1 07-13-2008 05:21 PM
