My wife called a repairman he said that the dishwasher needed a mtr, the mtr works, is there a way I can test the motor it doesn’t seem to be failing.
Originally Posted by: Dannyk My wife called a repairman he said that the dishwasher needed a mtr, the mtr works, is there a way I can test the motor it doesn’t seem to be failing. If you have a multimeter, Disconnect the motor harness, and do the following tests on the motor : White to Yellow 6.5 ohms (wash winding). White to Gray 6.5 ohms (drain winding). White to blue/wht 1.8 ohms (start winding). Give yourself 10% high or low and your motor will check to factory specifications. What is your actual complaint ? :cool: :cool:
