| » Whirlpool/Kenmore dishwasher impeller replacement |
Moved to Dishwasher repair section and made it a "sticky" so that it always shows up at the top. Excellent advice, richappy!
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
richappy,
Saw your impeller removal advice but wish to remove the 1/4 screw, then replace after cleaning an obstruction. For that reason, I don't want to crack the rubber washer. I've had a specialized nut busting solution on it for three days now so perhaps that will help. Do you know if the screw is REVERSE THREADED? Is it removed by turning clockwise? Thanks! |
Is there really no way to remove the impeller without destroying it?
I'm trying to remove the impeller so I can get to the screws under it that hold the filter in place, it's horribly clogged with hard-water build-up. |
Nevermind. I did exactly what you said NOT to do and grabbed it with a pair of channel-lock pliers. The screw came right out. No problems. I guess I need to replace the filter though, doesn't seem like it can be cleaned...
You where lucky, it was not seized, most of them are. Sometimes, if you twist it back and for a few times it will come off without breaking off. It shows some ability on your part to sense that it will not break off, good job.
__________________
Quote:
Ok, so I have a broken screw shaft on the impeller. It came that way when I bought it used. What is the part number, if possible, without ordering the entire thing? WHIRLPOOL | Model #GU1500XTKB0 | DISHWASHER | PUMP AND MOTOR PARTS | SearsPartsDirect.com $150 is preposterous! |
Quote:
If its cheap I'll try to fix it and donate it since I already ordered a new unit for delivery. |
| Display Modes | |
| dishwasher impeller instalation | tammydave | Dishwasher Repair | 1 | 04-11-2008 02:10 PM |
| How do you remove this impeller? | cabanaman_1999 | Dishwasher Repair | 6 | 04-10-2008 09:19 PM |
| 18" Whirlpool Dishwasher sleeve and seal replacement | joewlsh | Dishwasher Repair | 1 | 03-26-2008 09:22 PM |
| impeller kit replacement | zeisea | Dishwasher Repair | 2 | 03-10-2008 07:40 PM |
| dishwasher impeller installation | timoteo | Dishwasher Repair | 3 | 02-22-2008 03:14 PM |
