Discuss
Whirlpool/Kenmore dishwasher impeller replacement
 in
Dishwasher Repair
The center screw on my 18-year-old unit was very tight. I tried an adjustable wrench, an open end wrench, and
Appliance Repair Forum > Appliance Repair Help > Dishwasher Repair » Whirlpool/Kenmore dishwasher impeller replacement
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #41 (permalink)
Old 05-28-2018, 05:27 PM
Junior Member
Bucky2 is on a distinguished road
Default Tools to Remove Screw from Impeller
The center screw on my 18-year-old unit was very tight. I tried an adjustable wrench, an open end wrench, and a box-end wrench, but could not hold the top impeller well enough to loosen the screw.
I instead, used a 25mm socket (preferably a 6-point, but a 12-point worked) held in a pair of Vice Grips to hold the impeller. I then used a 1/4" socket in a 1/4"-drive ratchet through the 1/2" drive opening of the 25mm socket to remove the screw.
See photograph, attached.
The screw was extremely tight, but it did not break, and was not corroded when finally removed.
I needed to replace the filter and clean out the thousands of pieces after a tempered drinking glass shattered inside the dishwasher.
  #42 (permalink)
Old 09-29-2018, 06:22 AM
Junior Member
suzaanroshan is on a distinguished road
Default
Thank you for the helpful information you provided
  #43 (permalink)
Old 10-03-2018, 06:50 AM
Junior Member
saraesfehani2 is on a distinguished road
Default
thank you so much
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore chopper/impeller replacement Steve47 Dishwasher Repair 1 01-10-2010 04:15 PM
Dishwasher impeller replacement JRFOUNT Dishwasher Repair 3 10-08-2009 05:54 PM
Kenmore/Whirlpool Dishwasher Pump Motor Assebly Replacement tegold Dishwasher Repair 3 08-18-2009 12:12 PM
Whirlpool dishwasher impeller removal wonderdog Dishwasher Repair 1 09-20-2008 11:18 AM
impeller kit replacement zeisea Dishwasher Repair 2 03-10-2008 06:40 PM
