| » white-westinghouse dishwasher. |
Model Number: su770nxr1 Brand: White-Westinghouse Age: More than 10 years
i have a white-westinghouse dishwasher that is spraying water but the spraying arms do not spin. so the dishes don't get cleaned.
No easy answer here, you will have to make sure all the hoses and spray arms are clean and clear. Make sure the dishwasher is getting enough water. It should fill until the water level float shuts the water off, if it shuts off early the water valve may be bad and not letting enough water in, therefore you get bad wash because there is not enough water for the pump to make good pressure.
If all that check out you may have to open up the pump and inspect the impellers for damage or to see if anything in there is clogged (filter body-waterways etc) Good luck and let us know what you find so we can get you the correct part.
__________________
Those who don't learn from history are doomed to relive it! |
| Display Modes | |
| White Westinghouse Spacemate | dorothea | Washer Repair | 8 | 09-13-2009 09:06 PM |
| White Westinghouse Spacemate | dorothea | Washer Repair | 0 | 09-05-2009 12:44 PM |
| white-westinghouse electric dryer | xxandersonxx | Dryer Repair | 1 | 02-15-2009 06:32 AM |
| white westinghouse 2 speed | washing momma blues | Washer Repair | 1 | 12-15-2008 05:08 PM |
| Please Help.....White Westinghouse Spacemates | oceanmaid | Dryer Repair | 1 | 09-05-2008 04:16 PM |
