fblant
#1 Posted : Tuesday, August 10, 2010 5:22:15 AM(UTC)
fblant
My dishwasher flashes drain and rinse buttons at the same time. We turned off power and it reset and worked for a while, but then it happened again. THis happened a couple times but now it will not reset by turning power off. I changed the circuit box #8564542 (which is a little different) but only certain buttons work, not all. Please help!
Joe / APP Team
#2 Posted : Tuesday, August 10, 2010 8:01:17 AM(UTC)
Joe / APP Team
Based on the technical data sheet,
You have a bad touch panel.
(click on AP number for part information)
Part number: AP3138256
The technical data sheet in your unit is attached to the backside of the kickpanel, should you wish to run any additional tests or varify my suggestion.
fblant
#3 Posted : Tuesday, August 10, 2010 8:17:42 AM(UTC)
fblant
I was told by this website, that the touch panel does not come with anything except plastic part.Meaning there are no electronics attached. On my original touch panel, there is a connecting tape that would plug in to circuit. Is that included? Do I need to purchase that?
I really appreciate all you assistance.
Joe / APP Team
#4 Posted : Tuesday, August 10, 2010 10:17:21 AM(UTC)
Joe / APP Team
I'm a little confused :confused:
I don't have a 360 degree view of the control panel part.
But I'm sure the touchpad ribbon would be attached and not shown in the picture I sent you.
The information I do have, indicates that your unit does have a touchpad and ribbon assembly, that plugs into the control board.
As long as our information(from the manufacturer) is correct, you'll get what you need.
fblant
#5 Posted : Sunday, August 15, 2010 5:30:53 PM(UTC)
fblant
i want to thank you. We got the part. Replaced the control board, (cheaper than any other site) and did the first load yesterday. It was wonderful to hear it work again. You knew more than the Kitchen Aide site itself. This forum and this website is unbelievable and i will recommend it to everyone i know. I feel really accomplished by doing it ourselves and saved at least $400 dollars in labor and the cost of the part itself.
Thank you again
Fawn Lantes
Joe / APP Team
#6 Posted : Monday, August 16, 2010 6:24:16 AM(UTC)
Joe / APP Team
Thank you again
Fawn Lantes
Great,
I'm glad things went well, and you're up and running again.
Thank you, for the many compliments you've given AppliancePartsPros.com,
We do our best, and it's great to know we're appreciated.
Thank you very much.
fblant
#7 Posted : Wednesday, January 5, 2011 1:52:48 PM(UTC)
fblant
Hi Joe
You helped me previously replace the control touch on my dishwasher kitchen aide. Last night it was running and in the middle of cleaning. We checked to see if there is power going to the unit and there is. Do We need to replace the whole board now? Please help you helped soooo much last time.
Joe / APP Team
#8 Posted : Thursday, January 6, 2011 7:57:28 AM(UTC)
Joe / APP Team
Hi Joe
Fawn,
I almost missed it, but I think the dishwasher went dead during a wash cycle, correct ?
Since you do have power to the dishwasher,
First thing you want to check is the control panel thermo-fuse.
Part number: AP3178588
You've replaced the control panel, and had to have dealt with it, at that time.
If there is an open circuit on that fuse, it shuts the power to the control board off, and the dishwasher goes dead.
Of course, you may need to check the door switches and wiring down to the junction box on the dishwasher, if that fuse has a closed circuit.
You don't want to start at the control board first, that should be the last thing to check at this point, since the machine was working fine, unless there are obvious indications of damage on the board, when you open up the control panel.
Let us know, if or when you need help, and what you find wrong.
Good Luck,
fblant
#9 Posted : Saturday, June 9, 2012 4:10:06 PM(UTC)
fblant
Hi again,
I know you already helped me 2times with my dishwasher and i thank you. I have another problem with me GE monogram range top. It is working but it is cracked in 2 places. Is it possible to just replace the glass or do i have to purchase a whole new range?
Thank you again.
Fawn Lantes
Joe / APP Team
#10 Posted : Monday, June 11, 2012 5:08:17 AM(UTC)
Joe / APP Team
Hi again,
Thank you again.
Fawn Lantes
Fawn, You shouldn't need to replace the range. You will need to replace the cooktop portion of the range. If you can supply us with a model number from the range, we can assist you with a part number and basic "how to" instructions, just like before. In the mean time, try not to use the cooktop, it could shatter and create more isuues and possible personal injury.
Thanks,
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
