| » float detached from lever actuator |
Model Number: mdb5000awb Brand: Maytag Age: 5 - 10 years
Our float is detached from the lever actuator but the palnut is attached to the float. How do i attach the float to the lever?
Related Models |
Most likely the stem of the float is broken. Normally it just goes through and pushes the switch when there is no water.
__________________
Professional appliance repair in Orange County, California. |
The float pushes on the switch under the dishwasher when there is no water, causing the switch to close the circuit for the water valve.
If the float comes up with water, it releases the switch, causing the circuit to open. Gene.
__________________
| Display Modes | |
| Soap Dispenser lever snapped off | markdavies5 | Dishwasher Repair | 5 | 06-08-2009 10:17 AM |
| Float w/ washer necessary? | lwb | Dishwasher Repair | 1 | 07-30-2008 10:00 PM |
| Reconnect Kitchenaid Door handle/lever? | Longjack | Dishwasher Repair | 1 | 07-17-2008 01:55 PM |
| Timer lever replacement | landlord45 | Dishwasher Repair | 0 | 04-09-2008 11:12 PM |
| Water/icemaker lever on door will not work | boldpilot | Refrigerator & Freezer Repair | 3 | 07-24-2007 07:09 AM |
